|  | Home > Maintenance & Mods (L322) > Retro fitting Paddle Shift to early L322 |
| JPHC Member Since: 07 Sep 2015 Location: Kent Posts: 303      | Thanks for the reply mate. Hmm might have to do that then...
|  29th Jul 2016 1:29pm |
| mattstevenson2005 Member Since: 01 Jan 2011 Location: Manchester, UK Posts: 737      | You would need an extra 2 tracks on the slip ring as the heating element has 12+ Gnd and data, and the paddle shift system needs 12+ Gnd and 2 datas (basically Gnd connections for up and down shift)
|  29th Jul 2016 2:26pm |
| JPHC Member Since: 07 Sep 2015 Location: Kent Posts: 303      | Does make sense mate. Will have to rip the wheel apart this weekend and get the multimeter to work to get a good idea of how it's all setup for myself. Jordan
|  29th Jul 2016 2:40pm |
| daveo Member Since: 21 Oct 2009 Location: london Posts: 2307      | if i can remember i used the ground for the air bag for one and the live for the switches for the second V8 facelift Range Rover Autobiography 22" wheels.
|  29th Jul 2016 8:46pm |
| daveo Member Since: 21 Oct 2009 Location: london Posts: 2307      | hi
|  30th Jul 2016 4:50pm |
| JPHC Member Since: 07 Sep 2015 Location: Kent Posts: 303      | That would be great. Craig, you got such a thing mate?   | ||
|  1st Aug 2016 9:54am |
| Harris24742 Member Since: 18 Dec 2016 Location: London Posts: 3    |
 Hi all. A newbie here. Can i retrofit a 2012 vogue's steering wheel on 2008 vogue? I know the paddle shifters can be installed after a little modification of thw wiring but the control switches is what bothers me. Would the nav and other controls function similarly? I mean is it a bolt on setup?
|  18th Dec 2016 1:59pm |
| Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8826      | Pretty sure the "bus" systems are different so no you can't swap the airbag and switches, I think the bare wheel is the same though but you would have to check... Pete
|  18th Dec 2016 3:12pm |
| Harris24742 Member Since: 18 Dec 2016 Location: London Posts: 3    | I actually want to put the 2012 instrumental cluster and the 2012 steering wheel. Paddle shifters aren't needed but would be nice if i could manage the wiring. What i don't know is that whether or not the control switches can be installed on 08 | ||
|  18th Dec 2016 4:26pm |
| mattstevenson2005 Member Since: 01 Jan 2011 Location: Manchester, UK Posts: 737      | You can't fit a 2012 instrument cluster to a 08 L322. The MY59 L322 use a virtual instrument cluster and had a complete change in terms of wiring and CAN BUS. Pre MY59 vehicles use a 29bit CAN BUS whereas post MY59 vehicles use an 11bit CAN BUS network. The two are not interchangeable.
|  18th Dec 2016 6:21pm |
| Harris24742 Member Since: 18 Dec 2016 Location: London Posts: 3    | 2010? Or is 2010 and 2012 same steerings? Because there's no point of putting this if inwont be able to use the control switches | ||
|  19th Dec 2016 6:52am |
| mattstevenson2005 Member Since: 01 Jan 2011 Location: Manchester, UK Posts: 737      | Anything after mid 2009 uses the new system, only the older style steeering wheel controls will work with you vehicle.
|  19th Dec 2016 8:19am |
| Smiffyuk2017 Member Since: 15 Mar 2017 Location: Grimsby Posts: 2    |
 Unnecessary quote removed
|  15th Mar 2017 9:34pm |
| Lukie Member Since: 27 Sep 2016 Location: Liverpool Posts: 433    | in the FTO is the triptronic trigger by a negative pulse ? | ||
|  15th Mar 2017 10:03pm |
| Posting Rules
