![]() | Home > Maintenance & Mods (L322) > 4.4 tdV8 turbo oil drain mod. |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35867 ![]() ![]() |
picked my westie up at dinner time and all seems well...i've not tested it yet but i'm sure it will ok... ... - .- -.
FrankRizzo Member Since: 27 Aug 2012 Location: Frankfurt am Main Posts: 222 ![]() ![]() ![]() |
I'm considering upgrading to a 2012 4.4. The LTB005513v4 document states the issue affects VINs up to CA393639.
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2770 ![]() ![]() |
That VIN is the last L322. The 4.4 TDV8 in early L405 had the same problem. |
mines a july 2012 Frank and it had this problem, all sorted now |
Don't know if ours has this problem... Is it a recall or warranty job and how would you know you were afflicted?
the second turbo doesn't get used if you keep the rpm below 2500 which most do because of the lazy engine...the simplest way to test is to accelerate rapidly and make sure the rev counter goes over that rpm...if yours is suspect then you'll see loads of white smoke bellowing from the exhaust..
motorway slip roads are a good test bed for this fault...if you do have a fault then there will be quite a bit of white smoke coming from the exhausts on this test.. ... - .- -.
Not being funny but no turbo should be weeping oil in normal service! I'll put money on that turbo failing in the future as the seals have now been blown past their intended design... FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's Mantec Sump Guard, Rigid Load liner, MY10 BT upgrade. ![]() |
Could you not speak to landrover services and ask for a 'refund' for a fault that was known and not fixed when in warranty by them and show them the evidence that it was spotted as an issue thatnweses resolving? FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's Mantec Sump Guard, Rigid Load liner, MY10 BT upgrade. ![]() |
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 796 ![]() ![]() |
"Could you not speak to landrover services and ask for a 'refund' for a fault that was known and not fixed when in warranty by them and show them the evidence that it was spotted as an issue thatnweses resolving?"
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1430 ![]() ![]() ![]() |
kingpleb, I agree, and the problem is not that I don't get over 2,500 rpm, or town driving. The car is running fine, but I expect it is waiting for the most inconvenient moment for the turbo to fail... Only Range Rovers since 1988 |
£1000 fix if you are not in warranty.... |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3882 ![]() ![]() ![]() |
I have been told by my dealer that the mod is not covered by warranty.
Have you tried speaking to the warranty supplier or LR customer services direct?
