Home > Maintenance & Mods (L322) > DPF regeneration
Page 1 of 10 12345678910>
stu
DPF regeneration
Well that's the old girl serviced today, done the diffs, transfer box and all filters and oil.
I used the wiki to check the process for the oil and fuel filter, excellent write ups made it easy! Changing the oil couldn't be easier with the plug on the sump, don't even need tools!. Very Happy
Anyway I reset the service interval with the IID tool and went for a run, only to get the DPF message when I started her up.
I read the handbook and it says run above 50 mph for 20 mins. Is this the only/best way to do it, taking it on a run. Not a problem as I do about 35 miles each way for work. This coming on isn't a result of anything I've done service wise is it? Just coincidental. Current: TDV8 (3.6) RRS HSE
Past: TDV8(4.4) Vogue
Discovery 3 Commercial
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #443214 1st Jul 2017 4:07pm
If your daily run is 35 miles at speed then it would seem strange that the DPF needs to regenerate..
Usually thats when they are pootled round town that they get blocked up!
Can't see what you would have done service wise to upset it though. There is nothing that can't be fixed with a hammer😜😜
Post #443217 1st Jul 2017 4:22pm
nino_nino
Cam-Tech-Craig used to say that "she needs Italian tune up once in awhile".
Do mist the gay, always so helpful, and knowledgeable. he was essential in as figuring out where the oil leak was on ours 4.4TDV8. hope he comes back to forum.
Post #443224 1st Jul 2017 4:48pm
stu
NMJ..I don't use the FF for work every day, but my wife used it Thursday and Friday and was stuck in traffic and stop starting in road works and round town. Don't quite understand why that would make it happen either, but I shall drive it like I stole it on Monday to try clear it.. Current: TDV8 (3.6) RRS HSE
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #443230 1st Jul 2017 6:13pm
scotcruz
Scotland 2010 Range Rover HSE TDV8 Zambezi Silver
how easy was the diffs and trans oil change? where are the drain and fill plugs? Current:
- L560 Velar HSE R-Dynamic D180
- Peugeot 508 2011 - 2.2 HDi GT
Past:
- FFRR V 2010 - 3.6 TDV8
- Citroen C4 1.6i Petrol
- Mitsubishi Shogun 3.2 DID
- Peugeot 607 2.2 HDi
- Nissan Primera 1.8 SVE
- Honda Civic 1.6 VTEC
Post #443231 1st Jul 2017 6:21pm
stu
It's not hard, just that access is a pain! The rear diff and transfer box are easy, the front diff a bit fiddly as the engine subframe gets in the way a bit, I ended up putting the hex socket in the plug and using an open ended spanner to turn both the drain and fill plugs.
I have an oil suction gun which makes it easy to pump the fluids back in.
The fill and drain plugs are pretty obvious with the drain plugs at the bottom and the fill plugs on the side.
The rear diff drain is just a 3/8th ratchet as it's square, the fill is 8mm hex as are both trans box plugs.
The front diff is 14mm hex for both.
Hope this helps. Thumbs Up Current: TDV8 (3.6) RRS HSE
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #443232 1st Jul 2017 6:42pm
scotcruz
cheers bud.. I've got a oil pump too so will be easy to fill.. thanks for the heads up for the front diff.
What was the oil like? Current:
Past:
Post #443236 1st Jul 2017 7:02pm
stu
Actually not too bad! Current: TDV8 (3.6) RRS HSE
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #443237 1st Jul 2017 7:27pm
GGDR
Stu just to let you know a yellow DPF warning quickly changes to a RED which puts it into limp mode and you can't give it an Italian tune up.
So if you can't get it on a good blast DPF run then don't take it out until you can.
Been there myself.
And how hard was the transmission oil change?
. Cheers, Greg
Post #443238 1st Jul 2017 7:29pm
stu
Thanks for that! How far how fast to clear it? Current: TDV8 (3.6) RRS HSE
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #443239 1st Jul 2017 7:31pm
GGDR
Good discussion on it here:
http://www.fullfatrr.com/forum/topic42087.html?highlight=dpf
I think min 20 mins / min 2000rpm. Better 2500rpm
It's all about turning the DPF into an oven which burns off excess soot.
I put the cruise control on and the auto in S mode - then use manual flappy changes to keep the revs up even if the traffic slows I can still keep the tach over 2000.
But if you 've got a clear stretch hold it in 5th or 6th gear and go go go.
I could actually 'feel' the engine management doing things, like little variations and pulses in revs. Then presto after 25mins or so the orange light went out.
. Cheers, Greg
Post #443241 1st Jul 2017 7:42pm
stu
Thanks for that! I might go out early tomorrow when it's quieter.. Thumbs Up Current: TDV8 (3.6) RRS HSE
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #443242 1st Jul 2017 7:48pm
GGDR
Must have jinxed me - I got a DPF full warning today.
. Cheers, Greg
Post #443317 2nd Jul 2017 5:55pm
stu
Whistle Current: TDV8 (3.6) RRS HSE
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #443320 2nd Jul 2017 6:27pm
stu
Well that must be the most uncomfortable drive to work ever!! Didn't break any speed limits but kept revs between 2.5 and 3k for 35 mins.. Shocked
Warning triangle was still on as I pulled into work, but went off as I pulled in the car park! Let her run down for 5 mins after such a screaming. See if it comes back or stays clear on the way home. Here's hoping! Current: TDV8 (3.6) RRS HSE
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #443355 3rd Jul 2017 6:38am
