Home > Maintenance & Mods (L322) > DPF regeneration |
If your daily run is 35 miles at speed then it would seem strange that the DPF needs to regenerate..
1st Jul 2017 4:22pm |
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 |
Cam-Tech-Craig used to say that "she needs Italian tune up once in awhile".
1st Jul 2017 4:48pm |
stu Member Since: 04 May 2011 Location: Richmond North Yorkshire Posts: 927 |
NMJ..I don't use the FF for work every day, but my wife used it Thursday and Friday and was stuck in traffic and stop starting in road works and round town. Don't quite understand why that would make it happen either, but I shall drive it like I stole it on Monday to try clear it.. Current: TDV8 (3.6) RRS HSE
1st Jul 2017 6:13pm |
scotcruz Member Since: 03 May 2017 Location: S C O T L A N D Posts: 391 |
how easy was the diffs and trans oil change? where are the drain and fill plugs? Current:
1st Jul 2017 6:21pm |
It's not hard, just that access is a pain! The rear diff and transfer box are easy, the front diff a bit fiddly as the engine subframe gets in the way a bit, I ended up putting the hex socket in the plug and using an open ended spanner to turn both the drain and fill plugs.
1st Jul 2017 6:42pm |
cheers bud.. I've got a oil pump too so will be easy to fill.. thanks for the heads up for the front diff.
1st Jul 2017 7:02pm |
Actually not too bad! Current: TDV8 (3.6) RRS HSE
1st Jul 2017 7:27pm |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3519 |
Stu just to let you know a yellow DPF warning quickly changes to a RED which puts it into limp mode and you can't give it an Italian tune up.
1st Jul 2017 7:29pm |
Thanks for that! How far how fast to clear it? Current: TDV8 (3.6) RRS HSE
1st Jul 2017 7:31pm |
Good discussion on it here:
1st Jul 2017 7:42pm |
Thanks for that! I might go out early tomorrow when it's quieter.. Current: TDV8 (3.6) RRS HSE
1st Jul 2017 7:48pm |
Must have jinxed me - I got a DPF full warning today.
2nd Jul 2017 5:55pm |
2nd Jul 2017 6:27pm |
Well that must be the most uncomfortable drive to work ever!! Didn't break any speed limits but kept revs between 2.5 and 3k for 35 mins..
3rd Jul 2017 6:38am |
