Home > Technical (L322) > Reduced engine power warning
rar110
Today I experienced for the first time what I think was limp mode. The engine died in the ass, when is was just cruising at 70kmh and under 1500 rpm. I pulled over and the engine idled as normal. The warning disappeared. And it was ok after a restart. The IID Tool bought up the following messages.
P023D-22 (6C) Manifold absolute pressure - turbocharger/supercharger boost sensor A correlation - General signal failure - signal amplitude>maximum
Any suggestions? I’m thinking possibly split intercooler hose. ______________________________
Post #454628 20th Oct 2017 9:33am
checking the hoses would be my first job as well... ... - .- -.
Post #454630 20th Oct 2017 9:44am
rar110
Ta Stan. Yep will be doing the easy stuff first like hoses and MAP condition. Then sticky turbo actuator. Next, failing MAP.
Hopefully the search stops there.
Also I cleared and did another fault search while idling on the side of the road. The fault wasn’t repeated. ______________________________
Post #454639 20th Oct 2017 10:01am
PaulB
2017 Range Rover Autobiography SDV8 Loire Blue
Please keep this thread updated as i'm having the same code on and off.
Hope its an easy fix for you Thumbs Up
Post #454707 20th Oct 2017 9:35pm
rar110
Will do Paul.
Frightened the hell out of me as immediately thought a turbo had spontaneously gone pop. Quickly pulled over across three lanes of traffic, and popped the bonnet. Checked the engine bay for strange noise and oil, checked the exhaust for oil smoke. Nothing. ______________________________
Post #454715 20th Oct 2017 10:12pm
PaulB
My car goes bong and logs the code mainly if I'm under load, towing, especially up hill.
However it has cropped up a few times under normal acceleration.
Post #454725 20th Oct 2017 11:16pm
Take off and check the top right inter cooler hose. Will probably have split where it bends at the engine end under the webbing.
5 min job and most likely the cause. There is nothing that can't be fixed with a hammer😜😜
Post #454729 20th Oct 2017 11:32pm
rar110
I got into it this morning and quickly found a passenger side (right hand when looking at engine bay from front) intercooler hose was split on the top at the bend.
I also removed and checked the driver side pipe which was ok but had a bit of oil coated on the inside.
I repaired the hose with some silicone rescue tape that I keep in the car. I’ll try to find a pair of silicone hoses.
I also checked the MAPs which both look clean.
Post #454733 21st Oct 2017 1:46am
PaulB
Nice easy fix!!
Great news.
Post #454847 21st Oct 2017 8:23pm
PaulB
I think I need to get pressure test done. I can't find any leaks or splits but something isn't quite right.
Post #454849 21st Oct 2017 8:25pm
You sometimes need to take the hose off to see the split or it could be under the webbing. Also don’t forget the bottom hoses, there is another 2 at the bottom and some round the turbos as well. There is nothing that can't be fixed with a hammer😜😜
Post #454851 21st Oct 2017 8:32pm
rar110
I will get the lot replaced. Does anyone have the part numbers for the bottom turbo hoses?
I have the part numbers for the top hoses:
* PNH500510
* PNH500500. ______________________________
Post #454869 21st Oct 2017 10:03pm
rar110
I’ve been driving for about 5 days and the repair seems to be holding up. I still haven’t organised a replacement. ______________________________
Post #455302 25th Oct 2017 9:50pm
DavidS
Spain 2007 Range Rover Vogue SE TDV8 Java Black
Just be aware that as the hose is damaged it can still collapse internally and cause the dreaded bong, happened to me soon after my temp repair like yours.
Post #455369 26th Oct 2017 2:58pm
rar110
The silicone tape fell off and the fault reoccurred. So reapplied the tape and then secured the silicone tape by wrapping it in electrical tape. That held up better.
Today I fitted new silicone top hoses from a supplier in Oz. There seems to be a noticeable increase in performance. Has anyone else noticed this afterfitting silicone intercooler hoses?
Post #455920 2nd Nov 2017 8:08am
