Home > Technical (L322) > Reduced engine power warning |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34955 |
checking the hoses would be my first job as well... ... - .- -.
20th Oct 2017 9:44am |
rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119 |
Ta Stan. Yep will be doing the easy stuff first like hoses and MAP condition. Then sticky turbo actuator. Next, failing MAP.
20th Oct 2017 10:01am |
PaulB Member Since: 17 Jul 2011 Location: Hampton Posts: 877 |
Please keep this thread updated as i'm having the same code on and off.
20th Oct 2017 9:35pm |
Will do Paul.
20th Oct 2017 10:12pm |
My car goes bong and logs the code mainly if I'm under load, towing, especially up hill.
20th Oct 2017 11:16pm |
Take off and check the top right inter cooler hose. Will probably have split where it bends at the engine end under the webbing.
20th Oct 2017 11:32pm |
I got into it this morning and quickly found a passenger side (right hand when looking at engine bay from front) intercooler hose was split on the top at the bend.
21st Oct 2017 1:46am |
Nice easy fix!!
21st Oct 2017 8:23pm |
I think I need to get pressure test done. I can't find any leaks or splits but something isn't quite right. |
21st Oct 2017 8:25pm |
You sometimes need to take the hose off to see the split or it could be under the webbing. Also don’t forget the bottom hoses, there is another 2 at the bottom and some round the turbos as well. There is nothing that can't be fixed with a hammer😜😜
21st Oct 2017 8:32pm |
I will get the lot replaced. Does anyone have the part numbers for the bottom turbo hoses?
21st Oct 2017 10:03pm |
I’ve been driving for about 5 days and the repair seems to be holding up. I still haven’t organised a replacement. ______________________________
25th Oct 2017 9:50pm |
DavidS Member Since: 23 Jul 2014 Location: Valencia region Posts: 73 |
Just be aware that as the hose is damaged it can still collapse internally and cause the dreaded bong, happened to me soon after my temp repair like yours. |
26th Oct 2017 2:58pm |
The silicone tape fell off and the fault reoccurred. So reapplied the tape and then secured the silicone tape by wrapping it in electrical tape. That held up better.
2nd Nov 2017 8:08am |
