![]() | Home > Technical (L322) > Reduced engine power warning |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35827 ![]() ![]() |
checking the hoses would be my first job as well... ... - .- -.
rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119 ![]() ![]() ![]() |
Ta Stan. Yep will be doing the easy stuff first like hoses and MAP condition. Then sticky turbo actuator. Next, failing MAP.
PaulB Member Since: 17 Jul 2011 Location: Hampton Posts: 877 ![]() ![]() |
Please keep this thread updated as i'm having the same code on and off.
Will do Paul.
My car goes bong and logs the code mainly if I'm under load, towing, especially up hill.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8774 ![]() ![]() ![]() |
Take off and check the top right inter cooler hose. Will probably have split where it bends at the engine end under the webbing.
I got into it this morning and quickly found a passenger side (right hand when looking at engine bay from front) intercooler hose was split on the top at the bend.
Nice easy fix!!
I think I need to get pressure test done. I can't find any leaks or splits but something isn't quite right. |
You sometimes need to take the hose off to see the split or it could be under the webbing. Also don’t forget the bottom hoses, there is another 2 at the bottom and some round the turbos as well. There is nothing that can't be fixed with a hammer😜😜
I will get the lot replaced. Does anyone have the part numbers for the bottom turbo hoses?
I’ve been driving for about 5 days and the repair seems to be holding up. I still haven’t organised a replacement. ______________________________
DavidS Member Since: 23 Jul 2014 Location: Valencia region Posts: 73 ![]() ![]() ![]() |
Just be aware that as the hose is damaged it can still collapse internally and cause the dreaded bong, happened to me soon after my temp repair like yours. |
The silicone tape fell off and the fault reoccurred. So reapplied the tape and then secured the silicone tape by wrapping it in electrical tape. That held up better.
