Home > Technical (L322) > L322 4.4 TDV8 faulty oil level sensor
Page 1 of 3 123>
edward19
Hi All
My recently acquired 4.4 TDV8 oil sensor appears to be kapput (message on dash). Is there any way of replacing this without removing the engine to get the sump off? I've seen what looks like an oil dipstick hole (LHS of engine) and wondered if I could retro fit the 3.6 TDV8 dipstick to it. Any help would be great.
Thanks
Post #504810 11th Feb 2019 1:53pm
Baltic Blue
The tube you can see on the LHS is the oil extraction pipe, for changing the oil.
You can not use the electronic dipstick for at least 15 minutes after stopping the engine unless you do a crafty reset procedure.....
Select the service menu option, if it reads “Not available”
Open the bonnet
Do two quick presses on the cruise control “cancel” switch on the steering wheel.
The oil level should now show.
Mike.
Sorry I can’t post pictures for some reason, (probably slow internet connection)
Post #504811 11th Feb 2019 2:03pm
edward19
Oil level sensor
Hi Mike
Many thanks for the reply. Unfortunately the oil level sensor in my vehicle is defective and I cannot get any reading of oil. I was wondering if I could use the oil extraction tube to put some form of dipstick in it??
Thanks
Post #504812 11th Feb 2019 2:05pm
nino_nino
Unfortunately no, i try that some time ago as a way to check electronic oil level accuracy, but it did not work. if I remember rightly replacing oil level sensor is mayor undertaking Big Cry . 2012 TDV8 Black Edition
2000 Disco. TD5
1975 series III
Post #504820 11th Feb 2019 3:37pm
edward19
Thanks and what a nightmare that will be. I'm thinking about draining the oil through the extraction tube and measuring how much is in there. Ridiculous!!. However do you think it could be possible to remove the extraction tube and replace with the 3.6 TDV8 dipstick. Presumably the sump outlets will be different? Did you try this?
Thanks
Post #504833 11th Feb 2019 5:40pm
England 2016 Range Rover Vogue TDV6 Indus Silver
the 3.6 and 4.4 are different engines so if you did stick a dipstick in the 4.4 how long does it have to be...to many variables to do that me thinks..
are you 100% sure its the oil level sensor thats faulty?
Post #504834 11th Feb 2019 5:48pm
edward19
Hi
The dashboard suggests its faulty as it keeps saying oil sensor error.
Thanks
Post #504835 11th Feb 2019 5:50pm
Baltic Blue
I am not aware of anyone having to change one, but the picture in the workshop Manual shows it being external to the sump and bolted upwards ,
Take the plastic undertrays off and see it you can get access to it ??
Sorry I can’t post the picture, but it is in the engine external view PDF.
Mike G reg 2.5VM Vogue Portofino red 1991- 1999
Post #504836 11th Feb 2019 5:59pm
you could try checking fuse F20 in the engine bay fuse box and see if its blown...
Post #504837 11th Feb 2019 6:03pm
edward19
Many thanks. I will try the fuse and take a look underneath. Where you say bolt upwards, does it look like the bolt is on the outside of the sump?
Thanks
Post #504845 11th Feb 2019 7:50pm
Baltic Blue
Yes, it looks like 3 bolts. G reg 2.5VM Vogue Portofino red 1991- 1999
Post #504846 11th Feb 2019 8:01pm
gonna_go_double_r
Suggest, just to eliminate gremlins as a cause, doing a battery reset.
And how is your battery? Low batteries can cause all sorts.
. when I joined I was gonna_go_double_r,
now I've well and truly 'gone' double r:
Post #504851 11th Feb 2019 8:47pm
edward19
Thanks
I've just got a new battery but for some reasons it keeps getting wet!!!. Does anyone else have this drama?
Post #504853 11th Feb 2019 9:00pm
gonna_go_double_r
When did you get the error on-screen?
Just wondering about the correlation with fitting the battery?
Can you post a pic of the message?
Do you have an IIDTool?
If not, a good investment as the things are essential generally for this car. £300+ S/H, £405 new from Duckworths
I do remember reading another post of sensor failure have a search.
Post #504857 11th Feb 2019 9:13pm
edward19
Hi
Thanks. I can't take a photo just yet as I've just removed the high pressure fuel pump and the battery is on charge. Once it's all back together I will take a picture. I'm using a Delphi scanner at the moment but might get one of these IID devices.
Post #504859 11th Feb 2019 9:18pm
Page 1 of 3 123>
Site Copyright © 2006-2019 Futuranet Ltd & Martin Lewis
