Home > Technical (L322) > L322 4.4 TDV8 faulty oil level sensor |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3673 |
The tube you can see on the LHS is the oil extraction pipe, for changing the oil.
11th Feb 2019 2:03pm |
edward19 Member Since: 11 Feb 2019 Location: South Coast Posts: 44 |
Hi Mike
11th Feb 2019 2:05pm |
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 |
Unfortunately no, i try that some time ago as a way to check electronic oil level accuracy, but it did not work. if I remember rightly replacing oil level sensor is mayor undertaking . 2012 TDV8 Black Edition
11th Feb 2019 3:37pm |
Thanks and what a nightmare that will be. I'm thinking about draining the oil through the extraction tube and measuring how much is in there. Ridiculous!!. However do you think it could be possible to remove the extraction tube and replace with the 3.6 TDV8 dipstick. Presumably the sump outlets will be different? Did you try this?
11th Feb 2019 5:40pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34913 |
the 3.6 and 4.4 are different engines so if you did stick a dipstick in the 4.4 how long does it have to be...to many variables to do that me thinks..
11th Feb 2019 5:48pm |
Hi
11th Feb 2019 5:50pm |
I am not aware of anyone having to change one, but the picture in the workshop Manual shows it being external to the sump and bolted upwards ,
11th Feb 2019 5:59pm |
you could try checking fuse F20 in the engine bay fuse box and see if its blown... |
11th Feb 2019 6:03pm |
Many thanks. I will try the fuse and take a look underneath. Where you say bolt upwards, does it look like the bolt is on the outside of the sump?
11th Feb 2019 7:50pm |
Yes, it looks like 3 bolts. G reg 2.5VM Vogue Portofino red 1991- 1999
11th Feb 2019 8:01pm |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3519 |
Suggest, just to eliminate gremlins as a cause, doing a battery reset.
11th Feb 2019 8:47pm |
Thanks
11th Feb 2019 9:00pm |
When did you get the error on-screen?
11th Feb 2019 9:13pm |
Hi
11th Feb 2019 9:18pm |
