Home > Technical (L322) > 3.6 TDV8 issues following split boost/intercooler hose
Page 6 of 19 <123 ... 567 ... 171819>
cheezels
Australia 2007 Range Rover Vogue TDV8 Java Black
Info re throttle position sensing from the manual.
I May be interpreting it incorrectly but it seems a comparison between the sensors isn’t the philosophy, rather the sensors read different inputs independently to get a “picture” of what’s happening. 2007 3.6 TDV8
Post #510100 28th Mar 2019 1:52pm
cheezels
Dang!
No slipper. Back to the drawing board. Very Happy 2007 3.6 TDV8
Post #510101 28th Mar 2019 1:54pm
cheezels
The portion of video you mentioned shows 0 to 60 in about 9 or 10 seconds.
I’m not doubting you have an issue but the acceleration time seems about right, right? 2007 3.6 TDV8
Post #510105 28th Mar 2019 2:10pm
cheezels
This is quite interesting
 2007 3.6 TDV8
Post #510108 28th Mar 2019 2:27pm
MarianaWestminster
Had a read through and went out to test those solenoids with SDD.
I can command them to open and the actual values match so this suggests those solenoids work but of course doesn't discount a mechanical failure of the linkages.
Ive arranged to test drive an 08 3.6 L322 tomorrow to compare with my own just to be sure
Post #510243 29th Mar 2019 5:48pm
cheezels
Ok boss, let us know how the test drive compares please 2007 3.6 TDV8
Post #510283 30th Mar 2019 6:18am
MarianaWestminster
Ok been and had a drive of the 08 3.6.
Drives exactly like mine used to. No lag in the throttle when setting off and doesnt struggle.
Instant power when required.
Hmm
Post #510317 30th Mar 2019 12:32pm
MarianaWestminster
Ok, so took the upper boost hoses off tonight after work to double triple check and make sure I hadn't disturbed any connectors etc, also removed the n/s turbo to intercooler hose to check it didn't have any problems.
No issues found, put the car back together and nipped out for some milk.. ended up going for a 50 mile drive as it was driving so nicely!!
Thought I better make the most of it as it'll likely be back to driving crap tomorrow.
Post #510578 1st Apr 2019 10:14pm
GraemeS
Australia
You will need more milk so take it for another night-time run to see if it still behaves.
Post #510584 1st Apr 2019 10:30pm
?t=33 .
Post #510586 1st Apr 2019 10:48pm
MarianaWestminster
I need to see a customer this afternoon Graeme so the RR will get another 60 mile run. Will report back
Post #510603 2nd Apr 2019 9:10am
cheezels
Burn some sage and shower in holy water 😂
That’s good news. Weird, but good news 2007 3.6 TDV8
Post #510623 2nd Apr 2019 10:57am
cheezels
Reading through this thread, you’ve had this occur before, when you’ve removed the hoses to check all is well.
Rangie ran well and then got lethargic again.
If it’s not too much trouble, it would be interesting to see your data again for comparison.
Particularly if MAP 1 isn’t lagging behind anymore.
Sorry, not being a party pooper 2007 3.6 TDV8
Post #510628 2nd Apr 2019 11:23am
MarianaWestminster
As predicted... back to driving crap. Sick of the RR now.
What is removing and reinstalling the pipework doing?!?
Ill try removing it again and see
Post #510681 2nd Apr 2019 5:24pm
GraemeS
Australia
If you still have the original non-split hose then you could try refitting it in case that silicone hose is affecting air flow. It doesn't remove the silicone hose on the other side though.
Post #510722 2nd Apr 2019 8:51pm
