Home > Maintenance & Mods (L322) > EGR Delete photos ( update +1300miles) more miles
Page 5 of 12 <123 456 ... 101112>
MikeO
Scotland 2009 Range Rover Vogue TDV8 Buckingham Blue
It's not as bad as it looks but be very careful not to drop anything as Henda says. There's a good thread here. I posted a few tips on there.
https://www.fullfatrr.com/forum/topic48547-30.html 2016 Skoda Octavia VRS Estate
<gone>2009 FF Vogue TDV8 Buckingham Blue</gone>
<gone>2015 BMW 520D SE (not my favourite car)</gone>
<gone>2009 D3 HSE Galway Green</gone>
Post #508159 10th Mar 2019 11:27am
Andy
I did mine at the weekend. Little bit fiddly with the support bar bolts but only took an hour. The bolts in the bottom are captive so you can’t drop them.
I'm told there are two more tubes that run from the back of the manifold down to the exhausts. EGR Delete said they would make some blanks to remove those as well. Can't see the point to be honest.
Post #510214 29th Mar 2019 1:28pm
Henda
United Kingdom 2006 Range Rover Vogue TDV8 Zambezi Silver
Ran the FF up to kielder and got 32 mpg that's up and down the A68 ran all around kielder off road low gears burst an air bag then ran back down and averaged 27.6 for the weekend can't grumble there Thumbs Up
Can't believe how good they go off road ( nothing heavy ) tracks , mud water nd mud Thumbs Up
Post #510229 29th Mar 2019 3:41pm
Andy
Im not sure if it’s in my head but mine seems more rattly now under load. It’s nice and quiet on the move but moving off the traffic lights it sounds like an old Diesel engine.
I did speak to Andy at EGR Delete who supplied the blanks and he thinks it may have been remapped and not correctly. The diesel rattle could be advanced timing similar to pinking on a petrol engine. He also said the kit needs a digital delete to be effective although I can’t see why if they are sealed off now.
My TD6 ran well with the blanks for 9 years so I’m happy they make a difference.
Post #510266 29th Mar 2019 9:38pm
Lester Burnham
I did mine (2009 3.6 facelift) whilst its been sitting idle with gearbox problems. Crying or Very sad
As said a bit fiddly, that support bar was a PITA but done in well under an hour. being a short arse the worse thing I find doing anything on the RR is having to use step ladders!!!!
The odd few short hops I've done since would indicate a mile or two better mpg in mixed driving, not had any long runs. I don't know when the EGR is most active, idle, hard throttle or trailing throttle? If somone knows a garage in the NE who can do a digital delete for reasonable pennies I'd consider it.
Post #510504 1st Apr 2019 12:21pm
Andy
If you have the IID bt tool you can downsload a digital delete onto it from the BAS site for £200 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #510507 1st Apr 2019 12:45pm
telly-addict
Scotland 2011 Range Rover Vogue TDV8 Stornoway Grey
Did mine today. Yes a very straightforward job. Time will tell what the difference will be, but she seems a little more responsive.
Post #510709 2nd Apr 2019 7:25pm
Lester Burnham
Can blanking the EGR put pressure anywhere else? Since fitting the blank kit I noticed a slight oil drip last week which was not there before. It has got markedly worse today, enough to fill the undertray, despite minimal use of about 30 miles.
Looking upwards the highest point I can see wetted is where the steering column enters the power steering rack, however it may be dripping from elsewhere/above that and getting flung there by the driveshaft.
Please tell me this isn't anywhere near the turbo? Big Cry
Post #511317 8th Apr 2019 10:19am
Andy
Sounds like pure coincidence. Did you disturb anything when you blanked it off? 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #511319 8th Apr 2019 10:25am
Lester Burnham
No it was all just wiring up top.
So many coincidences? Confused
A friend standing by the drivers window at startup the other day said it was unusually smelly from that side, and he's a long term diesel owner. I must say I thought the same but wondered if the FBH was coming into play?
This whole car is starting to make me itch. I'm going off RR ownership rapidly.
Post #511322 8th Apr 2019 10:39am
WB
Thanks Henda for the great guide.
I’m looking to do this job and was a bit confused at the difference between this which seems like quite a straightforward job compared to the EGR replacement https://www.fullfatrr.com/forum/topic32601.html which seems like a much bigger undertaking.
Just want to check if I’m missing something or is it that the installing new EGRs needs a lot more access?
Also I was looking at kits - is there a favoured kit supplier? I was thinking about this one - http://www.egr-delete.co.uk/product/range-...-3-6-tdv8/
Thanks for your advice.
Post #511717 11th Apr 2019 6:00pm
Andy
That’s the kit I bought. They’re very helpful as well. They own range rovers so they know their stuff 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #511721 11th Apr 2019 6:37pm
telly-addict
WB wrote:
...I’m looking to do this job and was a bit confused at the difference between this which seems like quite a straightforward job compared to the EGR replacement https://www.fullfatrr.com/forum/topic32601.html which seems like a much bigger undertaking.
Just want to check if I’m missing something or is it that the installing new EGRs needs a lot more access?...
That's right, two completely separate jobs. As you saw the EGR replacement is quite involved, whereas the blanking kit is extremely straightforward as all you're removing is two small pipes that are easy to get to, fitting in their place some blanking plugs. Thumbs Up
Post #511725 11th Apr 2019 7:14pm
WB
Great, thanks telly-addict and thanks Andy, I’ve previously only replaced the two top inter cooler hoses so just wanted to make sure I wasn’t being over ambitious.
Thanks for all the help Bow down
Post #511730 11th Apr 2019 7:49pm
ur20v
A Trap
Deleted
Post #511759 12th Apr 2019 7:04am
