![]() | Home > My Range Rover > My Black Remapped 2004 TD6 Autobiography |
green-oval-nut Member Since: 02 Sep 2016 Location: Tunbridge Wells, Kent Posts: 930 ![]() ![]() ![]() |
Crank Case Cyclone Breather made by FEBI now fitted. I was dreading the job, but it was actually pretty easy. And also needed doing sooner than later as the old crank breather filter was almost solid! (Due to using my phone, the picture order got messed up lol)
Yesterday I was on another long journey and got fuel system error on the dash and limited acceleration, plugged my diagnostics in, came up with an EGR fault. So today, found the top pipe was perished, removed the EGR and cleaned it out. The carbon build up was so bad that even brake cleaner wasn't removing it, I ended up soaking the EGR valve in a bucket with fairy washing up liquid. (Worked a treat!), Only did this to get my car back on the road as I have a hell of a lot of miles to cover this coming week. I have ordered an EGR Valve blanking kit though, and will fit that as soon as it arrives. Annoyingly due to having to deal with cowboy tree surgeons that my next door neighbour hired, I forgot to take after photo's. But my Range Rover starts even better than before.
2 more days of long journeys, over 400 miles covered, and for a so called unreliable motor, Tank has been superb. Ferrying myself and a friend to and from court, used as a make shift but very comfortable mobile office to put a defence together (Iām not the defendant š) but been preparing a friend and her case for court for free. But this was finished off with a very late lunch. And finally I get a day off from everything tomorrow, depending on the weather. My EGR delete kit arrived Tuesday but the weather is forecasted to be wet and horrible. If it turns out to be dry, I will fit it.
The EGR delete kit has now been fitted, and the turbo breather filter has arrived and been fitted. It has made a hell of a difference to the starting, running & driving. Glad I managed to get it done today.
I have been naughty |
Despite having a broken foot, I got to go and have a bit of fun, 6 times |
Went on a bit of a road trip today, after getting errands done first, went & had lunch, stopped for fuel, this lead to a new route that the sat nav was taking us, and I realised that I was just around the corner from Eynsford Ford again, happy in the knowledge that driving through the Ford, would really annoy my Mum, off we went. To my surprise, we came across the site of a BMW that had attempted the crossing, but unfortunately sucked water into the engine, closing the road to lorries and coaches, including 1 that was waiting to get through. The BMW was full of pensioners and 1 young grandchild. So I towed it up to the pub so they had access to facilities, food & drink, whilst waiting for recovery. The woman who was driving was quite distraught though, as she explained that she had borrowed her husbands car. I wouldnāt want to be the owner of that car |
The last 3 days have been hell. Mostly surrounding a campervan that a good friend was ripped off with, but after getting that back on the road for her, I turned my attention to Tank. Thinking (Big Mistake) that the job planned would be a 2 hour job at most. Will I ever learn |
Swipe Member Since: 31 Aug 2018 Location: Rustington, West Sussex Posts: 101 ![]() ![]() ![]() |
I like reading your reports as a lot of the jobs youāve done i have done to my Td6. Also found that replacing the inter cooler, and turbo pipes to be a right pain. Access being the problem (no broken foot to contend with) the turbo hose this came loose 1 week after fitting it and the intercooler hose not clipping in securely.
Thank you for the heads up. I will try and make sure I am extra vigilant when securing the new hoses. Your heated rear screen if not a fuse or damaged lines in the screen is more than like a broken wire under the trim in the bootlid. Off the top of my head, I will be fitting a nudge bar, need to replace the rear bumper, fit drilled and grooved discs to the rear, replace the fuel pump in the rear wheel arch, fit light guards to the front and rear, fit chrome mirror covers, sort out the worst of the scratches, re-calibrate the suspension and customise the engine covers, thatās all I can remember off the top of my head. And so far covered over 1000 miles since the remap. After I have finished waking up today, I will be going for round 2 of trying to get the pipes off š |
You still have a big list of stuff to do š, thanks for the advice about the rear heated screen. I have tried to redo the lines, fuse and relay ok so will take the trim off and have a good look around. Was thinking of painting the engine covers at some point just not sure of colour to go for.
jim4244 Member Since: 31 May 2012 Location: UK Posts: 855 ![]() ![]() ![]() |
A great write up of day to day L322 ownership. š
2 Days of HELL with the Tank. If you are considering upgrading all the egr to intercooler and intercooler to turbo pipes, my advice is, DON'T unless you have a workshop, patience of a saint, and happen to have access to it all while other bits are out of the engine bay! It is by far the worst job I have done on a car. I have changed engines on French cars and used to run 2 garages. I will also say that in my opinion, of all the silicone hose kits I have ever fitted to cars, the only one I could find available for the TD6 is not of particularly good quality! I have fitted many silicone hose kits to many other cars.
God sounds like it was a real battle doing the hoses, I also thought the quality of the silcone hoses didnāt feel great. I must admit I didnāt have to cut pieces that had welded itself, but found replacing the turbo to intercooler pipes a pain just not great access and not being able to see things lining up.
