Home > Maintenance & Mods (L322) > What to do if your DPF is blocked...
Page 5 of 43 <123 456 ... 414243>
Baltic Blue
Rob,
Here is another screenshot out of my collection of dozens Rolling with laughter
It has changed on this one ?
Mike G reg 2.5VM Vogue Portofino red 1991- 1999
Post #518010 10th Jun 2019 9:15pm
Baltic Blue
Rob,
I don’t always monitor the same sensors, but I have been trying to compile a record of as many different live values as possible whilst my car is running well to use as a sort of reference to compare to when I do have a problem in the future.
One last one,
Post #518012 10th Jun 2019 9:35pm
GGDR
Quote:
Any idea why Bank 2 Sensor 1 hasn’t moved from 100?
Bank 2, Sensor 1 is just after the secondary turbo.
Floor it and that temp rises.
Under 2000rpm, it'll sit on 100 degrees all day.
. Cheers, Greg
Post #518018 10th Jun 2019 10:13pm
GGDR
Spitfire, I don't think you had a false, you said amber DPF and soon after the red
- this is true, it can go very quickly to red
If you do about a full tank of city driving only, under 40mph which I think is around 300 miles then in my experience that can take you form 3grams to 19-20 grams.
What can also happen is that your background Regen which would trigger automatically when you drive above 50mph may have been interrupted and instead of dropping down to 3-4g it could stop at 10-12 and then you may have driven 150 miles around the city and your DPF got up to above 23g.
(Hopefully that makes sense)
The DPF is actually really hard to manage unless you watch the grams number so without any OBD tool you can't see it - and it can take you by surprise.
. Cheers, Greg
Post #518019 10th Jun 2019 10:23pm
Baltic Blue
Bank 2 sensor 1.
Cheers Greg, as soon as I read your reply I knew that you were right, and that Nino had explained it before.
I had simply forgotten....
Old age, it’s a killer Rolling with laughter
Post #518030 11th Jun 2019 8:01am
DrRob
Odd, I don’t have Non Continuous Soot Mass as an option on my IID. Software was updated a few months back.
This is what I have:
Whistle Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #518080 11th Jun 2019 5:52pm
GGDR
That is strange DrRob. I will do a bit of research on it. You may want to email GAP because you need the grams figure as far as I can tell. Your value of 14.5 is not marked as grams and this may well be the grams number, but the 'soot in oil' reading does show a 'g' where the 14.5 doesn't.
I found this when searched one of your label titles "inferred using differential pressure"
In order to estimate the diesel particulate filter (DPF) soot load and improve the accuracy of regeneration timing, a novel method based on an equivalent circuit model is proposed based on the electric-fluid analogy. This proposed method can reduce the impact of the engine transient operation on the soot load, accurately calculate the flow resistance, and improve the estimation accuracy of the soot load. Firstly, the least square method is used to identify the flow resistance based on the World Harmonized Transient Cycle (WHTC) test data, and the relationship between flow resistance, exhaust temperature and soot load is established. Secondly, the online estimation of the soot load is achieved by using the dual extended Kalman filter (DEKF). The results show that this method has good convergence and robustness with the maximal absolute error of 0.2 g/L at regeneration timing, which can meet engineering requirements. Additionally, this method can estimate the soot load under engine transient operating conditions and avoids a large number of experimental tests, extensive calibration and the analysis of complex chemical reactions required in traditional methods. Cheers, Greg
Post #518115 12th Jun 2019 7:08am
Baltic Blue
I haven’t updated my iid since I bought it about 3years ago., and I am reluctant to do it now because I would have to start again from scratch with my library of live value screenshots.
Post #518116 12th Jun 2019 7:31am
DrRob
Thanks Greg. Odd isn't it. I searched both tested and non-tested menus in Live Values.
When did you last update your IID software? I did mine a few months back shortly after purchase (late January). It could be a new parameter that has replaced Non Continuous Soot ??
Have emailed Pat at GAP.....will report back. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #518117 12th Jun 2019 7:37am
Baltic Blue
The calculated soot in oil could be useful as a way of knowing when a change is due, but , I am happy to do 2 changes a year even though I only do 5-6 K miles a year.
What does the i symbol reveal ?
Post #518118 12th Jun 2019 7:40am
Baltic Blue
Rob,
Has your car just had an oil change ?, hence the 0 soot in oil reading ?
If so, it would be good to know the reading after every 1,000 miles.
You could then see what level reading corresponds to use.
Mine has a DPF remaining Volume reading measured in Litres, but it always seems to read Zero.
I have tried to find out why, but not got an answer.
Post #518130 12th Jun 2019 9:13am
DrRob
Soot in oil and remaining volume always show 0
Oil change months ago. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #518134 12th Jun 2019 9:35am
DrRob
From Pat at GAP:
"Live value list will vary depending on the engine and sometimes model year. I do not know if they are the same but the one you are looking at should give you an estimate of its state. " Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #518179 12th Jun 2019 2:07pm
Baltic Blue
Rob,
If you monitor the DPF soot concentration at the same time as the exhaust temperatures, you will soon see when an Active regen triggers.
If it rises from 14.5 to 17.5 in the next couple of weeks then you can expect to see it fall to around 2.3.
2 points to remember, (1 ) speed needs to be 50/60 mph.
(2) you need at least 1/4 full tank of diesel.
Mike.
N .B.
All 3 cars, yours mine and Greg’s are 2011 VSE. G reg 2.5VM Vogue Portofino red 1991- 1999
Post #518183 12th Jun 2019 3:01pm
Bill
gonna_go_double_r wrote:
In the meantime take it on a 50mph run for 30 mins
I might be wrong I’m Not technical!
I read somewhere that you need at least a third / qtr?? of a tank of diesel or the regen won’t start ....
Bill Filters are in fact so good that in certain circumstances, when the ambient air is already polluted, a diesel car will tend to extract more particles from the air than it emits. Emissions Analytics worked with........etc etc
He who dies with the most toys wins...
Post #518203 12th Jun 2019 5:49pm
