![]() | Home > Maintenance & Mods (L322) > What to do if your DPF is blocked... |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3880 ![]() ![]() ![]() |
Good evening gents,
Matt,
That is the recommended way to check for any air leaks on the inlets, but ?.
Matt,
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4348 ![]() ![]() ![]() |
Which Indy? AL Services? Bournemouth LR? Douglass ? Evans Garage? R&E?
Fair enough Matt, you seem to be getting good service from the dealer and hope we all learn from your experience.
Be good to see what their diagnosis will be. Greg mentioned potential throttle body issue - did LR Christchurch say that was an area to investigate?
Cracks in the Plenum chamber are common because the weld on the seam has failed, but again ,this would have shown up on the smoke test.
Matt,
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3560 ![]() ![]() ![]() |
Thought I'd show a regen happening at low speed / low revs:
As I understand, it measures exhaust pipe pressure before and after the DPF and from this calculates flow rate.
Cheers, Greg - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 2011 Vogue SE 4.4 with lots of toys in Stornaway |
Matt, not wanting to get involved but certainly curious
Fair enough! |
Component description of the differential sensor from the WM:
