![]() | Home > Technical (L322) > 4.2 Supercharged V8 Issues |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3272 ![]() ![]() ![]() |
Might be worth a call. http://derbyperformancehose.co.uk/index.html ? If you haven't already tried them. John 2008 Stornoway Grey 3.6 Tdv8 Vogue - SOLD 2005 TD6 Java Black Vogue - Written off!! GAP iiD BT-Sold |
MattHughes86 Member Since: 01 Jun 2019 Location: Gloucestershire Posts: 140 ![]() ![]() ![]() |
i will have a look.
so almost finished the strip down.
Also i have been looking at the manaual from the wiki for the AJV8,
Strider Member Since: 08 Jun 2015 Location: Hertfordshire Posts: 508 ![]() ![]() ![]() |
Matt,
found the crank sensor in the end.
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2264 ![]() ![]() ![]() |
Are you going to get the valve seats checker out while they are off I highly recommend it if it’s had gas Current stable:
it had the system in there but no tank in the boot, so i dont know if it was every hooked up?
I know what you mean but they can also go on petrol too just not as quickly. I know a place in leads an Cambridge you just need an engine workshop to check it over the kind of place that can skim heads etc id imagine. Current stable:
i still dont know if these heads can be skimmed?
Btw have you got the heads off yet? Though of an obvious way to check the valves need doing... just look at the valve clearance when you take the rocker covers off - if they are not right then get them done Current stable:
Almost got them off but havent quite got all the chains off yet.
Spud Member Since: 12 Jul 2019 Location: Asif by Magic Posts: 130 ![]() ![]() ![]() |
i will be watching that with pen and paper
