![]() | Home > Maintenance & Mods (L322) > What to do if your DPF is blocked... |
| Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1210 |
Matt, Thanks for your input I will give that a go today and let you know? |
| Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3883
Matt,
| GGDR Member Since: 26 Nov 2016 Location: London Posts: 3561
I've a thought /question on the drain mod, posted here:
Hi, BB,
Also i think it's not simply build up of soot, otherwise you could say that about your whole intake system. People do Terracleaning and the like but I'm not convinced.
If you are referring to the MAPT sensor ?.
Great comments, Tinman maybe get a second opinion?
Hi, Greg, I did try your guy first his price has gone up by £100 = £350
Unfortunately, despite the depth of this thread, the cause of a fast-filling DPF remains elusive.
Greg,
Agreed Mike.
...and I've also come to realise 300hp / 700nm and the ability to reach 38mpg is in fact too good to be true.
Like most people hear I run a second car, VW Golf GTD I put that in for the emissions defeat change which completely messed up the car and had to take it to a company to get it changed back to working as it should?
| DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4352
Looking forward to hearing Matt's update once LR Christchurch are done.... Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
