Home > Maintenance & Mods (L322) > Oil removal 4.4L TDV8
Page 4 of 13 <123 45 ... 111213>
Rambles
2011 Range Rover Vogue SE TDV8 Stornoway Grey
Hi
Where is the drain tube please?
Post #520950 7th Jul 2019 12:40pm
Baltic Blue
Just pull off the black plastic bung and attach the drain tube... right next to the oil filler cap.
Mike G reg 2.5VM Vogue Portofino red 1991- 1999
Post #520953 7th Jul 2019 12:50pm
matthews
United Kingdom 2011 Range Rover Vogue TDV8 Buckingham Blue
Twist it first then pull it off , I always drain the turbo return every year as there's a very slight possibility of sludge build up causing poor oil flow through turbos, (if it can't get out it can't get in ).
Post #520987 7th Jul 2019 5:51pm
K6rop
Thanks for all the info lads , bought myself a pump and going to do it this weekend
What was the tip for emptying the oil out ?
Post #522113 18th Jul 2019 3:12pm
K6rop
Forgot to add my picture 😂
Post #522114 18th Jul 2019 3:14pm
Baltic Blue
Simply prise out the outlet bung ( with the suction tube in the top ) with a screwdriver and you will see it is moulded in the shape of a spout, so just put a tundish into your empty 5 litre containers and pour it in Thumbs Up
Post #522121 18th Jul 2019 3:45pm
K6rop
Wow that was so easy , bought genuine Land Rover parts and the castrol oil they recommend £213 in total
Thanks for
all the pictures and advice
Post #522335 20th Jul 2019 8:34pm
DrRob
Start with 8L and then top up as indicated on sensor using the tips in this thread. I had to take mine back to garage tonight to have excess dropped as it was reading overfilled after an oil change. We dropped 2 litres then topped up as indicated on the dash. About 1L to bring to a normal level. Will be double checking cold tomorrow morning Thumbs Up
Background: Usual guy that works on my motors was stuck on MOTs but I texted him this evening and met me back at the garage after hours and we dropped the excess. Now that is top service Thumbs Up He was less than amused at his colleague’s error Censored
Helps that my mechanic mate is a Land Rover enthusiast of 45 years like me and has become a mate over last couple of years Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
I use www.glenrands.co.uk Great independent specialist!
Post #522689 24th Jul 2019 7:59pm
DrRob
This morning I read it cold and it said to add 0.5L. When warm it was one notch above middle line. Added 0.3L and it’s gone up one notch. Check again tomorrow.
Defo going to buy my own Draper pump like Mike’s (Baltic Blue) Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #522774 25th Jul 2019 4:25pm
Baltic Blue
They are a bit pricey Rob, but , compared to MD prices for an oil service , it will soon pay dividends.
I actually really enjoy doing as much servicing as I can, and at least I know it has got the right spec oil in.
Post #522785 25th Jul 2019 6:09pm
DrRob
Indeed Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #522804 25th Jul 2019 8:47pm
DrRob
Where do folks get their oil from? Advanced do 5L Ravenol for £42. There is cheaper but seems reasonable to me plus I get free delivery via their local delivery van Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #522820 26th Jul 2019 7:40am
GGDR
Dr Rob you need to use Shell Helix AF-L
Note the L which is important
You just missed on a mega deal, have a look in the bargain spots section
Maybe they'll get some more in
. Cheers, Greg
Post #522821 26th Jul 2019 8:04am
Baltic Blue
Rob,
Follow Greg’s advice and go for Shell AF-L.
In -excess have still got it in 1litre containers, but stress only AF-L.... nothing else Thumbs Up
Post #522825 26th Jul 2019 8:24am
DrRob
https://www.opieoils.co.uk/p-79221-shell-h...e-oil.aspx
Is there a promo code for forum?? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #522839 26th Jul 2019 9:46am
