Home > Maintenance & Mods (L322) > 4.4 tdV8 turbo oil drain mod.
Page 6 of 15 <123 ... 567 ... 131415>
GGDR
ok thanks Graeme. Great to know. Sounds like you might be in the trade?
Does anyone feel they would want to DIY this one?
The biggest task, aside of tapping the new hole, is the front diff and LH driveshaft have to come out.
I am kinda up of it and wondering if somebody would want to tackle this in duo with me? Two cars, two newbies, plenty of cross check - safety in numbers is what I'm thinking.
South East. Would have to find somewhere to do it too, feels like a ramp job.
Could be a good one, let me know?
Greg Cheers, Greg
Post #483959 21st Jul 2018 9:44am
GraemeS
Australia
I'm only a DIY'er (been one for nearly 60 years) although I didn't have any desire to tackle this job myself, perhaps partly because I generally work alone. However I also wanted insurance cover for the job in case metal shavings found their way into the sump. The 3.0 TDV6 task was simple and although I took nearly double the LR estimated time, it was only an afternoon's job.
Removing the drive-shafts from the diff and then the diff should be easy enough but note that I was unable to remove a hub from its driveshaft when attempting to change a front wheel bearing even though I had made a puller along the lines of the LR tool as the spline was exceedingly tight in the hub.
Post #483962 21st Jul 2018 10:05am
Baltic Blue
Greg,
I admire your pluck 🤔👍
I thought the whole front subframe had to either come out or at least be moved?
If it helps, the job took two and a half days when mine was done, but that was in a MD workshop with ramp etc.
Post #483975 21st Jul 2018 12:01pm
Mikeerhymes
United Kingdom 2011 Range Rover Vogue TDV8 Stornoway Grey
Looks like I need the oil drain mod, I’m well out of warranty so looks like I’ll be forking out to get this done.
Is there any need to look at replacing turbos whilst this is happening as most of the dismantling will have taken place?
I don’t suppose anyone can point me in the direction of an engine diagram with part numbers etc, I can’t seem to find anything for 2010-2012 4.4? Interested to see how it all looks, I assume they are a sequential setup with one either side?
Cheers
2011 4.4 TDV8 70k
Post #489264 18th Sep 2018 9:46pm
DrRob
JST wrote:
just had the mod done, �200 parts, �450 labour plus the initial diagnostic! local dealer wanted �1500 for same work.
just hoping the DPF will regen now, time will tell!
James. Who did the turbo drain mod for you?
Thanks, Rob Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #532633 30th Oct 2019 11:38am
Fox889
Thought I'd look under the n/s wheel looking just over the shaft to see if I had the mod already done........inspection light, mirror, could I find it, could I heck! I tried looking in front of the n/s wheel then behind the n/s wheel. There are two shiny LR pipes running together parallel but I'm guessing these are a/c, I don't seem to locate the longitude pipes......any clues for a dimwit? 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
Alfa Romeo Giulietta
Austin A40 Farina MK2
1975 Morris Marina 1.8TC
1973 Honda CB250 K4
Post #532810 31st Oct 2019 11:12pm
GGDR
You really need to get underneath. It's not easy at all though even from underneath.
Post some well it pics and we'll be able to tell you
. Cheers, Greg
Post #532811 31st Oct 2019 11:16pm
DrRob
If you're turbo has been diagnosed as "leaking" and you don't have the turbo drain mod then there is a train of thought going around to have the mod done first (~£1K) and see if that alleviates any oil leaks. Lot cheaper than forking out for a new turbo (£1.8K) plus fitting...
I'm doing a thread on where and how much here: https://www.fullfatrr.com/forum/topic53369...+drain+mod Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #532824 1st Nov 2019 8:26am
DrRob
Pictures on this thread might help
https://www.fullfatrr.com/forum/topic48944-30.html
Need to look behind the 2 horizontal AC pipes to see if it’s been done. Not easy by all accounts Whistle Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #533049 3rd Nov 2019 4:21pm
M@r]{
United Kingdom 2012 Range Rover Autobiography 4.4 V8 Barolo Black
I’m looking at buying one with over 100k Miles, with that mileage would it be a safe bet this would’ve already been done?
Post #533078 3rd Nov 2019 10:29pm
GGDR
Not necessarily Cheers, Greg
Post #533081 3rd Nov 2019 10:46pm
John w
United Kingdom 2011 Range Rover Autobiography Black TDV8 Barolo Black
And they may not suffer from the problem either.
Mine now has 106k on it and has not been modded, but it gets driven such that it's up the revs enough for the 2nd turbo to kick in. Too many toys, not enough time
2011 4.4 TDV8 AB Black
Post #533092 4th Nov 2019 12:56am
supershuttle
Mine doesn't seem to smoke at all, I don't know if the mod has been done but I make sure to "paddle down" a few gears on a long drive periodically to get the revs up to 3k or so. Geoff
Post #533094 4th Nov 2019 8:16am
jim4244
England 2005 Range Rover Vogue Td6 Zambezi Silver
I’m not in the UK at present and wonder if there is a way to check if the mod has been completed on a car I am interested in. I have the VIN and registration, so how would I go about checking?
Jim
Post #533096 4th Nov 2019 8:57am
M@r]{
Based on what I've read it is a bit tricky to check without getting underneath the car, and then it's not that easy! I'm in the market for a car, I've pretty much resigned myself to taking the car for a steady drive, then after a good 15mins of steady (under 2500rpm) driving, put my foot down and take it above 2500 rpm and keep an eye in the rear view mirror for a smole screen Smile
Happily be corrected though
Post #533107 4th Nov 2019 11:26am
