![]() | Home > Maintenance & Mods (L322) > Bottle Jack Modification to replace Scissor Jack |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4340 ![]() ![]() ![]() |
Mike - my thread will be using the Disco 2 bottle jack for roadside and SGS 3 tonne and adaptor for home work |
Has anyone found a 'pad' that can be put on the bottle jack to make it L405 compatible (not used it since having L322s ans it's a waste)?
Pad has arrived. Feedback shortly in a new “DrRob jacking thread”
2025MY Defender D350 90 in Silicon Silver on coils 1974 Series 3 Lightweight = "Millie" Many, many other Landies over the years My preferred specialist: www.glenrands.co.uk -------------------------------------------------- |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3839 ![]() ![]() ![]() |
Just a tip Rob, but make sure not to let the piston drop whilst you have got the saddle removed
Mike. Thanks. This adaptor is for using with my trolley jack. Pad to pad if that makes sense. I have a Disco 2 bottle jack for roadside wheel changing under the lower suspension arms |
The pad fits perfectly in the sill slot |
M@r]{ Member Since: 03 Nov 2019 Location: Northants Posts: 165 ![]() ![]() ![]() |
Anyone any thoughts on whether this would fit?
Bushy30 Member Since: 03 Jun 2018 Location: Powys Posts: 1099 ![]() ![]() ![]() |
It'll fit the car, you need to mod it to fit the jack Current: 2011 FFRR Vogue SE 4.4 TDV8
You don’t. need to drill it all the way through, just deep enough to get the pin back in.
darrenm Member Since: 06 Jan 2015 Location: chorley Posts: 188 ![]() ![]() ![]() |
Has anybody found a good place to buy a jack they all seem expensive on eBay |
Ok, my jack arrived the other day. £34.99 off eBay, brand new inc delivery. Rather than order the metal top a lot have done,
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 925 ![]() ![]() ![]() |
I found this in the back of our workshop today, a Weber Hydraulik 5 Ton bottle jack, I am going to file the ends off to have a flat surface and cut a 30mm x 55mm alloy rectangle 11mm thick or so, and weld it on for my L322
Pawl Member Since: 08 Nov 2017 Location: West Midlands Posts: 709 ![]() ![]() ![]() |
I've just purchased a brand new 2 stage 2T bottle jack on ebay for £40+ postage - as I couldn't find a Sprinter jack at a reasonable price.
Range Rover L322 Member Since: 03 Sep 2019 Location: South West Posts: 339 ![]() ![]() |
Duplicate deleted by author |
