Home > Maintenance & Mods (L322) > Bottle Jack Modification to replace Scissor Jack |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4228 |
Mike - my thread will be using the Disco 2 bottle jack for roadside and SGS 3 tonne and adaptor for home work 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
9th Jan 2020 12:02pm |
Has anyone found a 'pad' that can be put on the bottle jack to make it L405 compatible (not used it since having L322s ans it's a waste)?
9th Jan 2020 7:39pm |
Pad has arrived. Feedback shortly in a new “DrRob jacking thread” New Defender D300 90 on order so "Rory" will be going to a new home....! 1974 Series 3 Lightweight = "Millie" My preferred specialist: www.glenrands.co.uk -------------------------------------------------- |
20th Jan 2020 5:28pm |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3675 |
Just a tip Rob, but make sure not to let the piston drop whilst you have got the saddle removed
20th Jan 2020 6:51pm |
Mike. Thanks. This adaptor is for using with my trolley jack. Pad to pad if that makes sense. I have a Disco 2 bottle jack for roadside wheel changing under the lower suspension arms
20th Jan 2020 7:14pm |
The pad fits perfectly in the sill slot
21st Jan 2020 8:55am |
M@r]{ Member Since: 03 Nov 2019 Location: Northants Posts: 165 |
Anyone any thoughts on whether this would fit?
4th Feb 2020 2:53pm |
Bushy30 Member Since: 03 Jun 2018 Location: Oxfordshire Posts: 1097 |
It'll fit the car, you need to mod it to fit the jack Current: 2011 FFRR Vogue SE 4.4 TDV8
4th Feb 2020 2:59pm |
You don’t. need to drill it all the way through, just deep enough to get the pin back in.
4th Feb 2020 3:40pm |
darrenm Member Since: 06 Jan 2015 Location: chorley Posts: 179 |
Has anybody found a good place to buy a jack they all seem expensive on eBay |
4th Feb 2020 8:32pm |
Ok, my jack arrived the other day. £34.99 off eBay, brand new inc delivery. Rather than order the metal top a lot have done,
19th Feb 2020 10:53pm |
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 648 |
I found this in the back of our workshop today, a Weber Hydraulik 5 Ton bottle jack, I am going to file the ends off to have a flat surface and cut a 30mm x 55mm alloy rectangle 11mm thick or so, and weld it on for my L322
15th Jun 2020 7:57pm |
Pawl Member Since: 08 Nov 2017 Location: West Midlands Posts: 666 |
I've just purchased a brand new 2 stage 2T bottle jack on ebay for £40+ postage - as I couldn't find a Sprinter jack at a reasonable price.
19th Jun 2020 6:22pm |
Range Rover L322 Member Since: 03 Sep 2019 Location: South West Posts: 304 |
Duplicate deleted by author |
23rd Sep 2020 11:47pm |
