|  | Home > Technical (L322) > Electrical Gremlin Help |
| the_ferret82 Member Since: 10 Jan 2020 Location: Hertfordshire Posts: 50      | well made some inroads last night and managed to attach the computer to the car..
|  23rd Mar 2020 9:31pm |
| DucatiBrandon Member Since: 22 Feb 2020 Location: Arizona Posts: 19      | For giggles check the black box on the passenger rear side compartment. It’s the TPMS box. I pulled mine out the other day and dumped two cups of water out of it. This was causing all sorts of issues and I seen another guy have the same problems your having. Worth a look. Good luck | ||
|  25th Mar 2020 11:27pm |
| the_ferret82 Member Since: 10 Jan 2020 Location: Hertfordshire Posts: 50      | thanks for the heads up ill have a look tomorrow... it did seam dry that side. | ||
|  25th Mar 2020 11:30pm |
| Ragingrover Member Since: 05 Oct 2019 Location: Malvern Posts: 159      | Not very helpful I know but has all the hallmarks of a common ground connection or soldered joint breaking down. As said water definately doesn't help ... | ||
|  27th Mar 2020 10:54am |
| the_ferret82 Member Since: 10 Jan 2020 Location: Hertfordshire Posts: 50      | i managed to get some time yesterday to look at the TPMS module and other modules that's side of the car and they where all dry and showed no signs of water ingress. so happy there.
|  27th Mar 2020 11:21am |
| Ragingrover Member Since: 05 Oct 2019 Location: Malvern Posts: 159      | Depending how confident you are with wiring diagarms and schematics, then have a look on the Wiki section, pretty sure you'll find information in there.
|  27th Mar 2020 1:24pm |
| the_ferret82 Member Since: 10 Jan 2020 Location: Hertfordshire Posts: 50      | Hi Ragingrover,
|  7th Apr 2020 8:27am |
| the_ferret82 Member Since: 10 Jan 2020 Location: Hertfordshire Posts: 50      | Just a small update, had the car out a few times over the locakdown fro some shopping and when works has allowed, and the problem is still there. altho i have now started to notice a patten it seams to happen when its been cold over night / sudden drop in temperature.
|  9th May 2020 7:14pm |
| RR P38 Member Since: 12 Oct 2013 Location: Sydney Posts: 215      | Take a look at the ECU in the LEFT FRONT FOOT WELL
|  10th May 2020 11:48am |
| the_ferret82 Member Since: 10 Jan 2020 Location: Hertfordshire Posts: 50      | hi RR P38,
|  10th May 2020 2:57pm |
| RR P38 Member Since: 12 Oct 2013 Location: Sydney Posts: 215      | I have an 03
|  10th May 2020 11:23pm |
| RR P38 Member Since: 12 Oct 2013 Location: Sydney Posts: 215      | Out of curiosity what is your Alternator output and Battery state, Volts? | ||
|  10th May 2020 11:41pm |
| the_ferret82 Member Since: 10 Jan 2020 Location: Hertfordshire Posts: 50      | Hi RR P38,
|  11th May 2020 9:39pm |
| the_ferret82 Member Since: 10 Jan 2020 Location: Hertfordshire Posts: 50      | should alos add i have checked evey possible area for water ingress and i can find no signs of any. | ||
|  11th May 2020 9:43pm |
| Posting Rules
