Home > Maintenance & Mods (L322) > Oil removal 4.4L TDV8
Page 11 of 13 <123 ... 10 111213>
Rambles
2011 Range Rover Vogue SE TDV8 Stornoway Grey
Out of curiosity what’s the risk when driving overfilled?
Would you notice any different engine performance?
Post #602201 29th Jul 2021 3:06pm
Jayk69
United Kingdom 2012 Range Rover Vogue 4.4 V8 Barolo Black
There is risk especially if you are getting a overfill warning from cold as oil expands as it gets hot. how much over is it?
dont drive far
dont drive hard
remove the oil as soon as you can.
there may be better qualified people who will offer better advise
Tip for getting oil level to work
leave the bonnet up
when you get the message telling you to wait hit the cruise cancel button twice in 1 sec and you should get an immediate reading. this only works with the bonnet up i believe Thumbs Up 2012 Vogue 4.4 TDV8 - Current
2014 Navara V6 - Gone
2004 Vogue TD6 - Gone
Grand Cherokee - Gone
Discovery V8 (LPG) - Gone
Discovery TD5 - Gone
Post #602203 29th Jul 2021 3:26pm
DrRob
Correct on bonnet up process Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #602205 29th Jul 2021 3:57pm
Baltic Blue
Rob,
What do they do on the annual service other than oil and all filters ??
Post #602212 29th Jul 2021 4:57pm
DrRob
Service sheets in Wiki under Info at bottom. 3 types for the 4.4 on a rolling basis. Basically more filters every 2 years then pollen and oil on other one. Adjust handbrake annually. Coolant and brake at every x years etc. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #602216 29th Jul 2021 5:48pm
Baltic Blue
Thanks Rob,
I have basically abandoned dealer services and done whatever I think needs doing each spring and autumn.
One rainy day I will compile a DIY service sheet , but mine will include lots of little jobs that the engineer in me sees as sensible but often overlooked.
Eg.
Lubricate ( either a squirt of oil or finger full of grease, or both ) anything that moves, eg Clovis pins door hinges, bonnet release cable, etc etc.
I have accepted that I will never have a fully stamped service book, but will know what has been done and when.
Where on a service sheet does it say clean MAPT sensor ?, check antifreeze SG, etc… , but I am always keen to add to the list.
Post #602221 29th Jul 2021 6:31pm
DrRob
Update:
I had to take out roughly 1L to get the level to 2 notches above mid range for cold. It then showed 1 notch below max, 20min after a hot shut down.
They put in ~9.2L so ~8.2L in it now which correlates with others findings on here.
This is not the first time I've had to remove oil post service. My feeling is they throw in what's written in the book and do a quick check. Thank Censored I check and have my own pump BUT I shouldn't have to do this.
I dread to think how many are out there running too much oil Shocked
My 6 month change will be spot on. Why? Coz I do it Whistle Rolling with laughter Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #602258 30th Jul 2021 8:25am
DrRob
Post #602261 30th Jul 2021 8:39am
Baltic Blue
Rob,
Just a little tip regarding Draper pump.
Last time I got mine out of the box the plastic strip containing the measurements came adrift.
I suggest you get a permanent marker pen and mark up the container whilst yours is still stuck on.
Mike G reg 2.5VM Vogue Portofino red 1991- 1999
Post #602263 30th Jul 2021 8:47am
Kot
Baltic Blue, is that a high pressure sealing rag wrapped around that tube? Rolling with laughter 2018 SE SDV8 4.4 Byron Blue
Post #602264 30th Jul 2021 8:56am
Baltic Blue
Rolling with laughter Well spotted Thumbs Up
It’s looking well used now after about 5 years, twice a year changes, but I still highly recommend them, it makes doing an oil change so easy, even for an old doddering like me. Thumbs Up
Post #602268 30th Jul 2021 9:29am
DrRob
Thanks Mike! Will do Bow down
It will next be used in Jan for my 6monthly or for any mates in exchange for beers Whistle Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #602269 30th Jul 2021 10:09am
Kot
Mine arrived yesterday, influenced by these threads Thanks Bow down 2018 SE SDV8 4.4 Byron Blue
Post #602273 30th Jul 2021 10:18am
Kot
https://services.totalenergies.uk/too-much-oil-car 2018 SE SDV8 4.4 Byron Blue
Post #602274 30th Jul 2021 10:24am
Baltic Blue
You won’t regret the cost Kot, it soon pays dividends, and the peace of mind knowing that it has got the correct type and quantity of oil in the sump is priceless.
Just shout if you have any questions.
Cheers
Mike. ( always happy to help blue ones Rolling with laughter ) G reg 2.5VM Vogue Portofino red 1991- 1999
Post #602280 30th Jul 2021 11:33am
