![]() | Home > Technical (L322) > 4.2 supercharged misfire on idle |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1404 ![]() ![]() |
How many times have you ran the car in that 200 miles? Cel code only pops up after 3 runs with a pending code iirc |
friskydog Member Since: 16 May 2018 Location: West Midlands Posts: 78 ![]() ![]() ![]() |
I didn't know that. So...
Bean19844 Member Since: 25 Oct 2020 Location: Essex Posts: 929 ![]() ![]() ![]() |
A certain member on here had very similar problems going by your input. I'd start with the following mate and see where that leads you as it sounds like a fuelling problem.
Hi Bean, thanks for the message the spark plugs have been changed with the engine rebuild.
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2248 ![]() ![]() ![]() |
Was it me? Have you tried swapping coils over to see if the problem moves bank to bank? Current stable: 2006 BMW M6 2007 4.2 V8 S/C FF Gone: 2002 4.4 V8 FF |
I now am not seeing any Misfire alerts. However I have just thrown a P0174 system lean on bank 2 arrggghhhh.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8788 ![]() ![]() ![]() |
With no misfire codes it's unlikely to be coil packs, fuel rail and injectors are more likely... Pete
Thanks again Haylands first thing we will check in that case. |
4 injectors don't go bad at the same time all on one bank |
Hey Dingg,
It's not 4, one is enough to make the symptoms the OP has... the fuel rails give problems as well..!! Don't know how they deteriorate but it's a commonish issue... Pete __________________________________________________ 2014 L405 Autobiography SDV8 4.4 Loire Blue Ebony interior -Click here for Thread- 2012 L322 Autobiography 5.0 Supercharged Ipanema Sand Sold 2011 L322 Vogue SE 4.4 TDV8 Baltic Blue. Sold 2002 L322 Vogue 4.4 V8 Epson Green (Fatty Offroader) Sold -Click here for Project Fatty off roader- |
In mine you could watch the cylinder misfire counters going up on my scanner but not enough for it to throw a fault. New coils fixed it and did new plugs after too. Current stable: 2006 BMW M6 2007 4.2 V8 S/C FF Gone: 2002 4.4 V8 FF |
Thanks for that nugget of info Dan I will be checking them tomorrow with mechanic for sure. |
maric995 Member Since: 04 Apr 2019 Location: zagreb Posts: 58 ![]() ![]() ![]() |
Strong concetration of bg44k fuel cleaner will help you, it did solved constant missfire codes on my 4.4 ajv8 |
