Home > Technical (L322) > 4.2 supercharged misfire on idle
Page 2 of 4 <1234>
friskydog
United Kingdom 2007 Range Rover Supercharged 4.2 SC V8 Java Black
Thanks Haylands much appreciate that input. I will check it out. Thank you Thumbs Up
I have rest the alerts and driven 200miles since with no EML at all are these cars cursed? Range Rover Vogue SE 2007 L322 4.2 Supercharged 121k. Engine rebuilt @ 120666 Miles
Post #605601 4th Sep 2021 8:42pm
dingg1
How many times have you ran the car in that 200 miles? Cel code only pops up after 3 runs with a pending code iirc
Post #605606 4th Sep 2021 9:31pm
friskydog
I didn't know that. So...
I reset codes this morning.
I ran it up to Manchester and stopped for 45mins.
Then drove to city centre and stopped for 2 hours.
Then drove back from Manchester.
I will update you if It comes on again. Range Rover Vogue SE 2007 L322 4.2 Supercharged 121k. Engine rebuilt @ 120666 Miles
Post #605619 5th Sep 2021 12:02am
Bean19844
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Bonatti Grey
A certain member on here had very similar problems going by your input. I'd start with the following mate and see where that leads you as it sounds like a fuelling problem.
Spark plugs,
Fuel injectors (refurb or replace)
Fuel rails
You could I guess try chucking some injector cleaner in but that's not something I'd personally do as I've seen what it can do. I own a subaru impreza so short cuts are a strict no no with them.
Other then that take it too a specialist and get them too live read it and see what the fuelling is like
Keep us updated either way though mate
Post #605621 5th Sep 2021 12:19am
friskydog
Hi Bean, thanks for the message the spark plugs have been changed with the engine rebuild.
So I guess my question is if I get no more misfire codes but the engine still shudders at certain points at idle can mechanics narrow down which injector has the issue or do I have to replace all?
Before looking at fuel rails that is? Range Rover Vogue SE 2007 L322 4.2 Supercharged 121k. Engine rebuilt @ 120666 Miles
Post #605633 5th Sep 2021 8:48am
Danwilderspin
Spark plugs,
Fuel rails
Was it me?
Have you tried swapping coils over to see if the problem moves bank to bank? Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #605676 5th Sep 2021 11:02pm
friskydog
I now am not seeing any Misfire alerts. However I have just thrown a P0174 system lean on bank 2 arrggghhhh.
I am doomed with this car.
If with all the history of having a complete engine rebuild and the supercharger completely rebuilt and the fact i saw this same code pre all that work must mean it an historical problem which I am hoping is leaning towards fuel delivery.
However I have a mechanic looking on wednesday and will be checking coil packs and injectors as the next step. I am assuming this is the right thing to do?
I am preying its not fuel rails as they cost a fortune by the look of it. However if it solves it Ill pay what it takes.
I will update you all. Thanks again.
Cheers. Range Rover Vogue SE 2007 L322 4.2 Supercharged 121k. Engine rebuilt @ 120666 Miles
Post #605768 6th Sep 2021 7:37pm
With no misfire codes it's unlikely to be coil packs, fuel rail and injectors are more likely... Pete
-Click here for Thread-
Post #605778 6th Sep 2021 9:17pm
friskydog
Thanks again Haylands first thing we will check in that case. Thumbs Up Range Rover Vogue SE 2007 L322 4.2 Supercharged 121k. Engine rebuilt @ 120666 Miles
Post #605786 6th Sep 2021 9:51pm
dingg1
4 injectors don't go bad at the same time all on one bank Cool
Post #605787 6th Sep 2021 9:55pm
friskydog
Hey Dingg,
the misfire alerts havent come back after clearing errors for 250 miles now. So I wonder if it was a false positive. This P01074 code now seen is an historical one and one I had before engine and supercharger rebuild so I am suspicious of the injectors/coil packs and fuel delivery as that is an area that hasnt been renewed lately.
I will relay findings after Wednesday. Very Happy Range Rover Vogue SE 2007 L322 4.2 Supercharged 121k. Engine rebuilt @ 120666 Miles
Post #605789 6th Sep 2021 10:16pm
It's not 4, one is enough to make the symptoms the OP has... the fuel rails give problems as well..!! Don't know how they deteriorate but it's a commonish issue... Pete
Post #605790 6th Sep 2021 10:26pm
Danwilderspin
In mine you could watch the cylinder misfire counters going up on my scanner but not enough for it to throw a fault. New coils fixed it and did new plugs after too. Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #605800 6th Sep 2021 11:59pm
friskydog
Thanks for that nugget of info Dan I will be checking them tomorrow with mechanic for sure. Thumbs Up Range Rover Vogue SE 2007 L322 4.2 Supercharged 121k. Engine rebuilt @ 120666 Miles
Post #605805 7th Sep 2021 7:39am
maric995
Croatia 2006 Range Rover HSE 4.4 V8 Zambezi Silver
Strong concetration of bg44k fuel cleaner will help you, it did solved constant missfire codes on my 4.4 ajv8 Smile RR HSE 4.4 2006 LPG
Post #605810 7th Sep 2021 8:09am
Page 2 of 4 <1234>
