![]() | Home > Technical (L322) > 4.2 supercharged misfire on idle |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1393 ![]() ![]() |
How many times have you ran the car in that 200 miles? Cel code only pops up after 3 runs with a pending code iirc |
friskydog Member Since: 16 May 2018 Location: West Midlands Posts: 77 ![]() ![]() ![]() |
I didn't know that. So...
Bean19844 Member Since: 25 Oct 2020 Location: Essex Posts: 929 ![]() ![]() ![]() |
A certain member on here had very similar problems going by your input. I'd start with the following mate and see where that leads you as it sounds like a fuelling problem.
Hi Bean, thanks for the message the spark plugs have been changed with the engine rebuild.
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2246 ![]() ![]() ![]() |
Was it me? Have you tried swapping coils over to see if the problem moves bank to bank? Current stable: 2006 BMW M6 2007 4.2 V8 S/C FF Gone: 2002 4.4 V8 FF |
I now am not seeing any Misfire alerts. However I have just thrown a P0174 system lean on bank 2 arrggghhhh.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8713 ![]() ![]() ![]() |
With no misfire codes it's unlikely to be coil packs, fuel rail and injectors are more likely... Pete
Thanks again Haylands first thing we will check in that case. |
4 injectors don't go bad at the same time all on one bank |
Hey Dingg,
It's not 4, one is enough to make the symptoms the OP has... the fuel rails give problems as well..!! Don't know how they deteriorate but it's a commonish issue... Pete __________________________________________________ 2014 L405 Autobiography SDV8 4.4 Loire Blue Ebony interior 2012 L322 Autobiography 5.0 Supercharged Ipanema Sand Sold 2011 L322 Vogue SE 4.4 TDV8 Baltic Blue. Sold 2002 L322 Vogue 4.4 V8 Epson Green (Fatty Offroader) Sold -Click for Project Fatty off roader- |
In mine you could watch the cylinder misfire counters going up on my scanner but not enough for it to throw a fault. New coils fixed it and did new plugs after too. Current stable: 2006 BMW M6 2007 4.2 V8 S/C FF Gone: 2002 4.4 V8 FF |
Thanks for that nugget of info Dan I will be checking them tomorrow with mechanic for sure. |
maric995 Member Since: 04 Apr 2019 Location: zagreb Posts: 58 ![]() ![]() ![]() |
Strong concetration of bg44k fuel cleaner will help you, it did solved constant missfire codes on my 4.4 ajv8 |
