Home > My Range Rover > Trying this again ….. which diesel L322 way to go
Which is the best option given the details in this post:
1. 3.0 TD6 at c.£5.5k with c.£3k for repairs - c.100k miles and up to ‘06/‘56 plate
37%
 37%  [9]
2. 3.6TDV8 at c.£7k with £1.5k for repairs - c.150k miles and up to ‘07 plate
20%
 20%  [5]
3. 4.4TDV8 at c.£8.5k with £0 for repairs - c.200k miles and up to ‘08 plate
41%
 41%  [10]
Total Votes: 24
Page 6 of 7 <1234567>
Dolphinboy
@mjdronfield. Thumbs Up Bow down
Post #616786 17th Dec 2021 11:36pm
Slow progress
I never knew they even existed! Wow! They’d the perfect height for my 7yr old 😀👍 the one I’ve put the deposit on has them in the headrests, so some fiddling will be required to see if they work.
On the side steps, what rusts out ? Is it the sills, or the brackets for the side steps?
Post #616793 18th Dec 2021 8:03am
mjdronfield
They metal under the rubber that you step on tends to rust. It’s only thin. I’m heavy though 🤣. The brackets and car are strong though. Replaced them on both my cars. If you take the mud flaps off you will see a hole in the trim, so folk leave them on. You can leave it, fit steps or swap flaps for ones not meant for steps.
The early cars have the most comfortable seats as the air bags are in the doors, not the seats, so there is more adjustability around your shoulders. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #616803 18th Dec 2021 11:13am
mjdronfield
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #616807 18th Dec 2021 12:08pm
Slow progress
Deal done Thankyou all, will be back with plenty of questions no doubt. As a bonus it turned out the EGR is already blanked!
Will start contacting body shops in the new year, then a service. Could someone share bids us number as I’ll get the gearbox done as well, last serviced 36,000 miles ago
Post #618112 31st Dec 2021 9:08am
mjdronfield
I’ve still not managed to get hold of him…
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #618140 31st Dec 2021 11:50am
Slow progress
Likewise no joy. Used an acquaintance to service it in the mean time. Had the following done;
- Brake pads (front)
- Brake fluid
- front and rear diff oils
- transfer box fluids
- Gearbox service inc. filter change etc
- Battery with a new Yuasa one (low voltage reading)
- full service on the engine
- Crankcase breather upgrade to the vortex type
So as rebaselined as it can be mechanically.
Waiting on the dog guard and divider from Guardsman, fitting the boot tray today (NOS)
One small question what distance is it before the parking distance sensors start working?
Bodywork and leather next.
[/list]
Post #622437 4th Feb 2022 12:59pm
Slow progress
Think I may have finally found a good body shop!
It is approved for Jaguar and Land Rover repairs including dealer repairs and also does classics, mainly Minis and E-Types!
Taking the L322 up for a quote on Friday and if any good I’ll take series III as well , but anyone else close to Ilkeston might find it helpful. They have also done a Paddy Hopkirk Mini Cooper!!
https://www.larklandsderby.co.uk/
Post #623002 8th Feb 2022 8:21pm
mjdronfield
I need the arches tidying on mine. But don’t know a body shop I can trust. Hopefully a good job…
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #623014 8th Feb 2022 10:06pm
Slow progress
Will let you know. Suspect it’s going to be on the pricey side but if it’s as good as it appears then I’d be willing to pay a bit more for a good job.
Next quiz question….looking in the folder of bits I have the below remotes, what are they for;
Post #623029 9th Feb 2022 10:31am
mjdronfield
Doesn’t look like factory stuff.
Guessing you have screens in the back and they are for DVD player etc…. Not sure what the tag thing is. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #623031 9th Feb 2022 11:32am
Slow progress
Found the damned squeak!!
Sticking rear drivers side brake calliper. Just driven back from the Bodyshop squeaking most of the way back, pressing the brake pedal stops the noise! Release it and it comes back, when I got home the heat coming from that wheel was amazing, wish I still had my pyrometer!
Post #623284 11th Feb 2022 1:01pm
Slow progress
Just agreed to the bodywork repairs…….£1228 including a dent and paint repair to the front passenger door and wing (both small). Arch repairs are advised as rub down and paint as there’s enough metal left to work with.
We will see what’s hiding behind the sill covers and rear wheel arch liners, that’ll be extra depending on what’s in the proverbial Pandora’s box
Lastly I’ve asked for photos so people can judge their work that way it may be of use to other members. It’ll be going in on the 4th of April which will give me time to get the brake calliper sorted and a few other jobs.
Post #623872 16th Feb 2022 9:04am
Slow progress
Rear callipers replaced and PAS fluid. Driving a lot more smoothly after getting a lot of maintenance under its belt👍
Goes back to the garage on Wednesday to chase down;
1. Replacement front parking sensor
2. Inactive air suspension (although it’s still at the correct ride height)
3. Inactive HDC
4. Replacement rear wiper arm (it’s corroded on!
5. Front passenger side window regulator as something is causing it to stick and jerk about 1” from the top
6. Rear passenger side window switch as it’s still opening and closing on its own unless the child lock is applied
7. Air con check (regas perhaps)
Getting there bit by bit! L322 TD6 2003
Epsom Green- the dogs car which has worked it’s way into being the family car 😮
Post #626159 14th Mar 2022 6:17pm
Slow progress
Just a quick update as I packed the L322 (still working on a name for it) off to the bodyshop this morning, we shall see what is hiding behind the plastic sill and arch covers. In the mean time painting plans are rear arches as they are solid enough to repair without new metal, dent in passenger front door and front wing to be repaired and painted, and the big one repaint the entire roof as some of the paint is missing and it’s down to bare aluminium! £1950 all in…pending Pandora of course!
Recent bills;
- £320 for 2 new rear callipers and pads.
- £590 for 2 new parking sensors, 2 new ride height sensors, front passenger side window actuator and rear passenger window switch
Getting there bit by bit, quite a lot of longer term consumables needing doing and a little bit of wear and tear items. L322 TD6 2003
Post #627786 5th Apr 2022 10:57am
