![]() | Home > My Range Rover > Trying this again ….. which diesel L322 way to go |
| Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3280
@mjdronfield. |
| mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 8000
They metal under the rubber that you step on tends to rust. It’s only thin. I’m heavy though 🤣. The brackets and car are strong though. Replaced them on both my cars. If you take the mud flaps off you will see a hole in the trim, so folk leave them on. You can leave it, fit steps or swap flaps for ones not meant for steps.
| Slow progress Member Since: 30 Jun 2020 Location: Derbyshire Posts: 453
Deal done Thankyou all, will be back with plenty of questions no doubt. As a bonus it turned out the EGR is already blanked!
I’ve still not managed to get hold of him…
Likewise no joy. Used an acquaintance to service it in the mean time. Had the following done;
I need the arches tidying on mine. But don’t know a body shop I can trust. Hopefully a good job…
Will let you know. Suspect it’s going to be on the pricey side but if it’s as good as it appears then I’d be willing to pay a bit more for a good job.
Doesn’t look like factory stuff.
Found the damned squeak!!
Just agreed to the bodywork repairs…….£1228 including a dent and paint repair to the front passenger door and wing (both small). Arch repairs are advised as rub down and paint as there’s enough metal left to work with.
Rear callipers replaced and PAS fluid. Driving a lot more smoothly after getting a lot of maintenance under its belt👍
Just a quick update as I packed the L322 (still working on a name for it) off to the bodyshop this morning, we shall see what is hiding behind the plastic sill and arch covers. In the mean time painting plans are rear arches as they are solid enough to repair without new metal, dent in passenger front door and front wing to be repaired and painted, and the big one repaint the entire roof as some of the paint is missing and it’s down to bare aluminium! £1950 all in…pending Pandora of course!
