Home > In Car Electronics (L322) > Fitting my Naviplus / air play unit |
Bl4ckD0g Member Since: 16 Feb 2020 Location: 127.0.0.1 Posts: 1322 |
I wouldn’t think the lvds messes with that. It is likely the aux port indeed. |
24th Jan 2022 9:55pm |
davethomas83 Member Since: 12 Dec 2015 Location: Gloucester Posts: 30 |
Good evening all - just started my NaviPlus journey today ( 2012 tdv8 4.4 Single View Screen ) . . . Suffice to say not completely straight forward.
9th Feb 2022 7:33pm |
I don’t know the dip switch settings for a single view screen nor whether the dipswitch is the only difference.
9th Feb 2022 7:53pm |
Thanks Bl4ckD0g,
9th Feb 2022 8:03pm |
Good luck. My gut feel thinks it’s the ground as they skipped that part in the manual. And also if one isn’t used to print board connections it requires inserting those connectors with more force and depth than one can be comfortable with.
9th Feb 2022 8:55pm |
Thinking about it - have I been foolish I’m not disconnecting the battery ?
9th Feb 2022 9:06pm |
Oops yes, definitely disconnect. And wait 20 or so minutes before you do that. Blimey you are lucky getting the airbag out without taking the power off eeeeekkkk
9th Feb 2022 9:54pm |
So, battery disconnect hasn’t helped ( although did clear the airbag warning light 😂 ).
11th Feb 2022 9:26am |
Oh yours looks fairly different that my dual view system. I’ll take a look later today when I have access to a big screen.
11th Feb 2022 9:38am |
Perhaps you disconnected it just at the time photo was taken but if not you have to fix that to the same board. |
11th Feb 2022 9:39am |
This is the ldvs cable, is that not how I should earth it ?
11th Feb 2022 10:14am |
I earthed mine to the actual print board screw inside the enclosure. That is what naviplus told me. |
11th Feb 2022 10:28am |
Ahh ok - I’ll give that a good next then.
11th Feb 2022 10:38am |
Hmmmm I'm trying to look at the big screen, but yours is significantly different. Amazing for just dual vs single view.
11th Feb 2022 5:43pm |
