![]() | Home > Technical (L322) > Help me out with the suspension on my 'famous' 4.4TDV8 L322! |
| mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 8002
That’s the trouble, I don’t know if it’s actually faulty now or was before….🤣 Sorry, not helping Sam I know….
| Ffrr-lover Member Since: 04 May 2021 Location: Lincolnshire Posts: 640
Realistic? Probably not, its just a term often used and my car is FAR from that!
The 7 digit error codes are listed in the Workshop Manual, which you have prob seen already. The diagrams show 3 sensors, along with the 4 height sensors, but then the text seems to list that a good few more sensors are used…..
| coopss Member Since: 21 Apr 2018 Location: Hampshire Posts: 281 |
I had the same issue. Turning the stability control on/off made no difference so I know it was stuck in hard
| JayGee Member Since: 27 Jul 2021 Location: London Posts: 3404
I'd also suggest rigging a PSU up to manually open the shock valve solenoids and seeing if it softens the ride. On my Audi Allroad which had air suspension and adjustable shock absorbers you could adjust the shock stiffness.. Curiously sport was less crashy at low speeds and going over potholes etc and comfort was better at high speeds where sport was unbearably crashy which seemed the opposite of what it should have been. 2012 TDV8 Vogue (L322) |
| GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2784
Constant 12V will keep the valves open. The system can operate the valves almost 100% duty cycle (as close to 100% that a pwm signal can be generated) when required to be soft. |
| Reidsr Member Since: 31 Dec 2021 Location: Aberdeen Posts: 10
Any further on with it Sam? |
| MarianaWestminster Member Since: 14 Jun 2018 Location: UK Posts: 758
Hello everyone,
Well, to coin an old phrase….. there are more questions than answers……. Unfortunately
Welcome back Mariana!
Thankyou FFRR-lover!
Well, I hope you tracked those 100 miles as a few will be having a meet up to see if theirs adapts back 🤣
Even more interesting.
Strange.
| All times are GMT |
