Home > Technical (L405) > I'm now a Regeneration trainee nerd--lol
Page 21 of 30 <123 ... 202122 ... 282930>
Gremlin500
Hi Kot, yes normally, I would agree.
But, in this case, the regen kicked in at half the average distance, and when almost none of the “warm up” conditions or even possibly speed, had been reached.
In other words, high soot % can and will override everything, which increases the chances of a failed regen due to road & traffic conditions.
Call it “Regen or Bust” mode Shocked
Just something for peeps to be aware of, and not sail too close to the wind…… planning is everything. “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #685062 8th Feb 2024 11:17am
AndyRoo
Scotland 2012 Range Rover Westminster TDV8 Fuji White
Hi, there seems to be some folks who are thinking fuel in the oil is down to failed DPF regenerations, this is not true, fuel gets into the sump during the exhaust stroke regardless of whether the regen is successful or not as the DPF is downstream of the exhaust port, i.e. the diesel (or most of it) has already passed through the engine before it reaches the DPF.
There is a case to say that if the engine is turned off that any unburnt fuel in the engine does not get blown out the exhaust and therefore trickles down into the sump, but this is also a false flag as the same would apply to normal operation when the engine switched off mid stroke regardless of if a regen were active or not.
The truth is, it happens because of porus rings, i.e. the better the ring sealing the less likely diesel is to get to the sump, worn rings, scored bores or in the occasional instance where the ring gaps actually align during the process will make the problem worse. a coked up engine is actually a good thing in this regard as there is less chance of unburnt fuel reaching the sump. Fuji White / Jet 2012 4.4 TDV8 Westminster
Post #685067 8th Feb 2024 11:40am
Gremlin500
@AndyRoo:
You are not quite correct in what you say, during the regen process the engine is deliberately overfuelled. If the process is interrupted, it will reinitiate again and again until it succeeds. This extra fuel increases the dilution effect. The engine management algorithm takes account of this, and drops the MTS accordingly.
No-one is saying diesel from the exhaust can find its way into the sump, that’s absurd. Thumbs Up
There are a few good reference articles on this subject which make interesting reading. “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #685087 8th Feb 2024 2:33pm
AndyRoo
Hi, thanks for the explanation, every day is a school day Thumbs Up
Andy Fuji White / Jet 2012 4.4 TDV8 Westminster
Post #685089 8th Feb 2024 2:40pm
Kot
One of the trigger points is the average distance between Regens. Thumbs Up
Of course if you do a lot of 30-40mph events then soot load will of course rise faster than the average distance etc Thats why the soot grams pid, I now find, is a more useful guide to when its going to actually trigger. 2018 SE SDV8 4.4 Byron Blue
Post #685094 8th Feb 2024 3:00pm
Ok, DPF gurus, I’m needing a bit of help making sense of these figures, I’m struggling to find the same values as previous posts using my IIDtool.
Ta
 Got - 2017 SDV8 Autobiography in Loire Blue
Post #686510 26th Feb 2024 7:15pm
luxmoggy
Germany 2019 Range Rover Autobiography SDV8 Montalcino Red
most of us are using a different dongle and software for measuring/monitoring the values.
I didn't find all of the values with the GAP tool, but I didn't spend lots of time looking as the other software was what was being used. SDV8 AB MY 2020
MINI Cooper S Cabrio
Kit: Jaguar XK140 (in progress - the website is link to build)
Post #686537 26th Feb 2024 10:21pm
Gremlin500
Hi Alan,
I agree with Kot, its better to use the Vgate BT dongle and Car Scanner Pro app dashboard, you can see it safely & clearly whilst driving.
Info at the beginning of this thread. Thumbs Up
Price for both total under £20 now. “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #686554 27th Feb 2024 8:52am
CerebralThunder
I have a L405 2015 3.0 Hybrid (I posted about it earlier in the thread).
This model/year doesn't show the same sensors as everybody elses in the thread for some reason...
I've made sure that I am doing everything correctly and had help from the excellent luxmoggy (thank you for sending your dashboard to me) as well as contacting the developer. The developer didn't really work with my to find a solution just saying to add to my dashboard what sensors were available.
Here are some screenshots of sensors that I found that I thought might be relevant:
As you can see, I am currently up to 840 miles between regens and am currently monitoring (I can't see a way to see what/how the trigger is).
Should I be worried?
The car gets good, long runs quite frequently (Midlands to South Wales and Midlands to Lancaster) and daily runs of 20 miles (10 miles each way) to and from work.
Can anybody advise if there is something I can do to chaeck all's well? The car, although approaching 10 years old, is still under the full LR warranty.
Thanks all.
Post #686890 1st Mar 2024 2:22pm
TonyHammer61
England 2017 Range Rover Autobiography SDV8 Barolo Black
Hi Andy. That is interesting as I had always put the oil dilution down to regen's not happening. What can I get JLR to check instead of them just telling me to change my driving style and changing the oil - again? My mate has a 67 plate L405 4.4 SD V8 just like mine. Hardly uses it and never gets these oil dilution issues. Some have suggested that the sensor is faulty or the software is malfunctioning
Post #686893 1st Mar 2024 2:29pm
Gremlin500
Hi Tony, I think you may have missed my response to Andy back up the thread. You were correct, it IS multiple failed regens which really rack up dilution. It’s a known fact that the JLR diesels suffer from dilution, due to the “remote DPF architecture” and the inability for passive regeneration to occur, at least to a significant level, when much of the driving is “short & slow”, hence the need for Active Regeneration.
Of course, if you don’t use the vehicle, you will not soot up the DPF, nor will it need to regen, nor will dilution happen, but that’s one expensive ornament sitting on the driveway!
Kot Bow down Bow down Bow down has very kindly posted up several scholarly articles on this subject, they make enlightening and interesting reading……. Well worth seeking them out and reading. Whistle “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #686900 1st Mar 2024 4:26pm
TonyHammer61
Thank you Gremlin500
Post #686901 1st Mar 2024 4:28pm
fisha
CerebralThunder
The dpf value your looking to monitor out of those screenshots is the DPF soot concentration on an IIDTool.
On my 4.4 tdv8, it’s this value which builds up to around 20 ish in value, and then on a regen will burn down to about 6 or 7 iirc. ( i cant remember exact values, but its in those sorts of ball park figures ).
You then want to also monitor the exhaust temp sensors … on mine, the main one I monitor I think is bank 1 sensor 2 iirc. It’s the one which will see the temp rise way beyond 550degC on a regen, although I normally will select a few of the sensors to display to figure it which is the best one.
Lastly, simply monitoring the live mpg value can be enough to tell if the car is trying to build temp for a regen. On mine, if it’s time for regen, once up to temp, cruising on roads at around 50 will drop the normal live mpg figures down towards 22-24 instead of fluctuating above 30 on light throttle.
On the IIDtool, there doesn’t seem to be any option of display regen status like the other software talked about here …. Which is a pity, but hey ho.
I still think it’s bonkers that the car doesn’t display / report it’s doing a regen. V8 or else ...
Post #686932 2nd Mar 2024 1:28am
CerebralThunder
@fisha
Thank you very much for the reply. I'll use the soot as a trigger point and also see if I can see the increased exhaust temperature as a reminder to keep driving..
What are your thoughts (and anybody elses) on the fact I'm over 800 miles since the last regen and still my soot concentration is only showing 14? Does that seem ok?
Thank you.
Post #686975 2nd Mar 2024 5:58pm
Kot
CT
We haven't come across your vehicle type before an hybrid V6, is it the same engine as the L405 non hybrid V6?
What profile are you using on the scanner app? it might be worth experimenting with the profiles.
If you are using Range rover profiles you can also look in Landrover profiles for a profile that has your engine etc The basic default profile is the OBDII profile that again might be worth trying for your case
You should be able to see at a minimum Exhaust temps, DPF soot grams, trigger %, DPF status (o,1 or 2) and you can set alarm/colour change etc so its noticeable when changes occur.
Over 800 miles is amazing when certainly the V8 manual states AR occurs at average of every 250 mile! maybe its the Hybrid influence? OR
It may be because you haven't got the correct profile saved for the car yet?
It would be interesting once you get all your settings in place to see the graphs. How does your Hybrid effect fuel consumption compared to non hybrid V6 as a matter of interest.
Graphs? go to Data recording and look at the saved files of each journey. You can pick what you want see below graph showing recent Active Regen
Good Luck enjoy the journey Rolling with laughter 2018 SE SDV8 4.4 Byron Blue
Post #687030 3rd Mar 2024 10:53am
