Home > Maintenance & Mods (L322) > What to do if your DPF is blocked...
Page 42 of 43 <123 ... 414243>
JayGee
The usual reason for rapid soot buildup is an airleak on the intake either at one of the 4 intake rubber connectors or where the large connector attaches to the alloy throttle body. Either check for sooty and oily deposits coating these areas or get the garage to do a high pressure smoke test. 2012 TDV8 Vogue (L322)
Post #693102 22nd May 2024 7:16am
Range Rover L322
. 2012 L322 4.4 TDV8 AB low mileage - a peach
1986 V8 Defender 90 County ex-Swiss Army - Red everything....
My preferred Independent: Roy Hardy. R & B AUTOS LTD, 20 Brook Road, Wimborne, Dorset, BH21 2BH 07500 866775‬ (Ex LR Chief Technician)
Post #693115 22nd May 2024 11:19am
JayGee
More soot will be generated when it's cold due to longer warmup times. Also the manufacturers change the blend during cold months to prevent wax forming but not sure if this has any influence on soot buildup but if it's an addative that makes the fuel less efficient it may do. 2012 TDV8 Vogue (L322)
Post #693120 22nd May 2024 12:09pm
RRLG16
Thank you for your reply. The car is a 16 reg and the previous owner had full service history direct from JLR. So we presumed it was well looked after.
Unfortunately we had already taken it to the local garage. They’d tried a clean and said they werent able to clear it, hence the suggestion of a new part. I guess they’ve gone from option 1-3 on the original post.
I’ve called the Indy garage and they said there’s only been one they’ve been unable to clear so will take it there on Tuesday. It’s either going to be paying for 2x cleans at the two different garages & learning my lesson to take it to the Indy first, or paying for 2 x cleans plus an entire new part.
To be honest I regret buying the car. The engine light came on on my birthday a few months back & I was sat around for 40 mins as didn’t want to drive it and cause further damage (turns out it was ok to drive as amber and not red & was related to the airbag)
Thank you for the car reader suggestion too. I did invest in an Icarsoft scanner. Cant scan at the moment as I’ve left it at the first garage! I think they’d said they’d tried to clear it to an amber to be able to clear but weren’t able to. I’m just not too sure how the second garage will be more likely to clear if the first weren’t able to?
But yes, noted, I’ll take it to the Indy next time to start.
I’m in Worcestershire.
Thanks for your reply!
Post #693178 23rd May 2024 11:32am
RRLG16
Post #693179 23rd May 2024 11:33am
matthews
United Kingdom 2011 Range Rover Vogue TDV8 Buckingham Blue
I've had a few issues over the last 6 months after having a nightmare journey with constant stop start traffic and allowing the fuel to get too low to regen , sorted po40d, had intermittent oxy sensor issue which I replaced (bosch part is £100 LR part is £200 + and is a bosch part !!), after unsuccessful attempts at cleaning on car i took it off (unbolts from LH turbo outlet and cat and 2 cuts in tailpipes ) for a proper cleaning , cost £150 to clean with 2 year warranty , currently it's behaving well and I'm regularly plugging the gap in to check readings but so far so good . Personal advice is take it off and get it cleaned as it's not silly money and you know you are starting with a clean DPF when resetting everything .
Post #693659 30th May 2024 7:49pm
JayGee
Who did the DPF cleaning? 2012 TDV8 Vogue (L322)
Post #693679 31st May 2024 8:46am
matthews
I'm in Leeds and the co is ITS turbo's (i've used them for about 15 years for turbo rebuilds) but they've started cleaning dpf's over the last few years , there cleaner is big enough to fit the dpf in with both inlet pipes fron LH turbo and RH cat on so only 2 cuts required on outlets (which i made on the straights that are arbout 40 deg to longditudal line of car before the bends where they go back straight ), they are in Drighlington on the outskirts of Leeds , £150 +vat with 2 year warranty and usually 24/48h turnround , local to me so dropped it off n picked it up a couple of days later. RR is not only transport as have old Disco as works van, dog wagon general run around for muckier jobs , RR is for weekends, long journeys and tugging tin tent or car transporter for work if needed as Leeds is a joke for anything with dpf and rapidly getting worse .(can't wait till i move north next year ).
Post #693799 2nd Jun 2024 8:53pm
JayGee
Logging my regen interval at around 130 miles doing a constant 70mph which is likley a consequence of ash load after 170k miles and toying with having it cleaned. 2012 TDV8 Vogue (L322)
Post #695076 25th Jun 2024 7:47pm
Mcdaddyjester
Not on a RR but I had VW T5 camper that had a DPF light on constantly. The DPF burnt off the carbon but left the soot. I removed the DPF, flushed it out for 30 mins with pressure washer and refitted. Never had a problem after.
Post #707612 25th Dec 2024 9:05pm
Hardy
Germany 2011 Range Rover Autobiography 4.4 V8 Galway Green
Hi all,
newbie member here.
First of all, a huge thank you to all the contributors here - especially from the DPF experts! Incredibly helpful and time & money saving!
Still have a question:
Recently got a L322 4.4D. I monitor my soot level with the Gap IID tool. The soot level rises rapidly, so I suspect a leak somewhere.
Be that as it may, I have now repeatedly noticed that I have not received an amber warning when exceeding the amber warning threshold (23.3g). Instead, if I don't do a forced regen with the IID, the soot level rises until it I hit a red DPF warning and limp mode.
Does anyone know this behaviour and has any idea what could be causing this?
Thanks a lot,
Hardy
Post #717248 1st May 2025 8:28pm
pcourtney
good info below - check it out and let us know how you get on Smile
https://www.fullfatrr.com/forum/topic73344.html
Post #717251 1st May 2025 9:12pm
Hardy
Thanks! Have read the thread.
I still don't understand why I don't get an amber DPF warning when the soot level is above the amber threshold. It goes straight to red.
Any thoughts or ideas?
Hardy
Post #717252 1st May 2025 9:34pm
Range Rover L322
Hardy wrote:
Hi all,
newbie member here.
Thanks a lot,
Hardy
Hi Hardy,
Some thoughts.
1) It's not a great idea or practice to be regularly forcing a regen. You should only use a Forced Regen as an absolute last resort.
Reasons: i) You can damage the matrix. ii) If you are having to do it regularly, you are over-sooting and you need to find the cause of oversooting not empty the receptacle (the DPF).
19.7g Demands Regen
23.3g Amber Warning On
27.5g Red Warning On
17.46g Amber Warning Off
21.25g Red Warning Off
2) If you're going to red regularly you've likely got a split in a hose. You are going to red because it is sooting fast.
you want to be running the IID tool all the time. I am going to guess you are getting less than 2miles per gram inferred (=split).
The fields you want to watch are Demanded Regens, Exhaust Gas temps.
With your issue, the first thing I would be doing is a high pressure smoke test
3) See pages 33 and 40 of this post.
Just to tidy up some of the other figures.
• You need 1/4 tank of diesel to regen.
• 37mph is the trigger speed. I can trigger a regen in traffic when the car is at temp by simply blipping it over that speed.
• The frequency at which the L322 demands a regen increases with inferred soot. i.e. it will demand more regens more as it goes up through 20/21/22 grams.
• Another note is to ignore the IID Tool Successful Regen field. it is completely unreliable. Demanded Regens works perfectly and is the one you want .
• IID tool: the Oil dilution field is calculated not measured - ignore - it is meaningless.
• We learned L322 s often behave differently. Their behaviour is not consistent - you will need to learn and adapt for your particular car.
For context I spent several years and more than £20k on this issue (see page 40 - we basically rebuilt the car). Included in the people I consulted with/had working on it were a LR Chief Tech of now 24 years experience. A leading UK 4x4 modder. And, amazingly, some of the original L322 design team.
The posts I’ve produced on this topic are fairly definitive and include clear conclusions on DPF removal and EGR blanking — namely, it’s worth doing on the 3.6, but not advisable on the 4.4. This forum used to be a really collaborative place, but I stopped contributing when too many self-appointed experts started arguing for the sake of it. I know what I’m talking about, and when the tone shifted, I honestly just couldn’t be bothered / don't have the time — I deleted a lot of info rather than get dragged into it
I hope that all helps you Hardy. Good luck
Post #717354 3rd May 2025 10:32pm
Hardy
Hi Matt,
thank you for the excellent summary and up to date guidance on what to do!
I literally read the whole thread back to back.
Your and the others' contributions have brought me so much further in my understanding of the matter and most probably saved me a lot of money.
Anyway, you are right: Will do a high pressure smoke test.
I had already removed the intake inlet manifold and checked the 4 hoses but could not finde any cracks. Same for the intercooler to throttle body hose: no cracks and the 'fix' with the 4 rubber rings applied.
Differential pressure sensor voltage is also inconspicuous.
Have already booked my car in for a smoke test, but only in 6 weeks - very hard to get it done quickly with one of the few RR specialist indies here.
Thanks again,
Hardy
Post #717407 4th May 2025 8:22pm
