![]() | Home > Maintenance & Mods (L322) > What to do if your DPF is blocked... |
Range Rover L322 Member Since: 03 Sep 2019 Location: South West Posts: 339 ![]() ![]() |
. 2012 L322 4.4 TDV8 AB low mileage - a peach
More soot will be generated when it's cold due to longer warmup times. Also the manufacturers change the blend during cold months to prevent wax forming but not sure if this has any influence on soot buildup but if it's an addative that makes the fuel less efficient it may do. 2012 TDV8 Vogue (L322) |
RRLG16 Member Since: 21 May 2024 Location: England Posts: 3 ![]() |
Thank you for your reply. The car is a 16 reg and the previous owner had full service history direct from JLR. So we presumed it was well looked after.
matthews Member Since: 09 Aug 2016 Location: Leeds Posts: 104 ![]() ![]() ![]() |
I've had a few issues over the last 6 months after having a nightmare journey with constant stop start traffic and allowing the fuel to get too low to regen , sorted po40d, had intermittent oxy sensor issue which I replaced (bosch part is £100 LR part is £200 + and is a bosch part !!), after unsuccessful attempts at cleaning on car i took it off (unbolts from LH turbo outlet and cat and 2 cuts in tailpipes ) for a proper cleaning , cost £150 to clean with 2 year warranty , currently it's behaving well and I'm regularly plugging the gap in to check readings but so far so good . Personal advice is take it off and get it cleaned as it's not silly money and you know you are starting with a clean DPF when resetting everything . |
Who did the DPF cleaning? 2012 TDV8 Vogue (L322) |
I'm in Leeds and the co is ITS turbo's (i've used them for about 15 years for turbo rebuilds) but they've started cleaning dpf's over the last few years , there cleaner is big enough to fit the dpf in with both inlet pipes fron LH turbo and RH cat on so only 2 cuts required on outlets (which i made on the straights that are arbout 40 deg to longditudal line of car before the bends where they go back straight ), they are in Drighlington on the outskirts of Leeds , £150 +vat with 2 year warranty and usually 24/48h turnround , local to me so dropped it off n picked it up a couple of days later. RR is not only transport as have old Disco as works van, dog wagon general run around for muckier jobs , RR is for weekends, long journeys and tugging tin tent or car transporter for work if needed as Leeds is a joke for anything with dpf and rapidly getting worse .(can't wait till i move north next year ). |
Logging my regen interval at around 130 miles doing a constant 70mph which is likley a consequence of ash load after 170k miles and toying with having it cleaned. 2012 TDV8 Vogue (L322) |
Mcdaddyjester Member Since: 08 Nov 2024 Location: Worcester Posts: 5 ![]() ![]() |
Not on a RR but I had VW T5 camper that had a DPF light on constantly. The DPF burnt off the carbon but left the soot. I removed the DPF, flushed it out for 30 mins with pressure washer and refitted. Never had a problem after. |
Hardy Member Since: 24 Mar 2025 Location: Hamburg Posts: 3 ![]() ![]() ![]() |
Hi all,
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 923 ![]() ![]() ![]() |
good info below - check it out and let us know how you get on |
Thanks! Have read the thread.
Hi Hardy, Some thoughts. 1) It's not a great idea or practice to be regularly forcing a regen. You should only use a Forced Regen as an absolute last resort. Reasons: i) You can damage the matrix. ii) If you are having to do it regularly, you are over-sooting and you need to find the cause of oversooting not empty the receptacle (the DPF). 19.7g Demands Regen 23.3g Amber Warning On 27.5g Red Warning On 17.46g Amber Warning Off 21.25g Red Warning Off 2) If you're going to red regularly you've likely got a split in a hose. You are going to red because it is sooting fast. you want to be running the IID tool all the time. I am going to guess you are getting less than 2miles per gram inferred (=split). The fields you want to watch are Demanded Regens, Exhaust Gas temps. With your issue, the first thing I would be doing is a high pressure smoke test 3) See pages 33 and 40 of this post. Just to tidy up some of the other figures. • You need 1/4 tank of diesel to regen. • 37mph is the trigger speed. I can trigger a regen in traffic when the car is at temp by simply blipping it over that speed. • The frequency at which the L322 demands a regen increases with inferred soot. i.e. it will demand more regens more as it goes up through 20/21/22 grams. • Another note is to ignore the IID Tool Successful Regen field. it is completely unreliable. Demanded Regens works perfectly and is the one you want . • IID tool: the Oil dilution field is calculated not measured - ignore - it is meaningless. • We learned L322 s often behave differently. Their behaviour is not consistent - you will need to learn and adapt for your particular car. For context I spent several years and more than £20k on this issue (see page 40 - we basically rebuilt the car). Included in the people I consulted with/had working on it were a LR Chief Tech of now 24 years experience. A leading UK 4x4 modder. And, amazingly, some of the original L322 design team. The posts I’ve produced on this topic are fairly definitive and include clear conclusions on DPF removal and EGR blanking — namely, it’s worth doing on the 3.6, but not advisable on the 4.4. This forum used to be a really collaborative place, but I stopped contributing when too many self-appointed experts started arguing for the sake of it. I know what I’m talking about, and when the tone shifted, I honestly just couldn’t be bothered / don't have the time — I deleted a lot of info rather than get dragged into it I hope that all helps you Hardy. Good luck . 2012 L322 4.4 TDV8 AB low mileage - a peach 1986 V8 Defender 90 County ex-Swiss Army - Red everything.... My preferred Independent: Roy Hardy. R & B AUTOS LTD, 20 Brook Road, Wimborne, Dorset, BH21 2BH 07500 866775 (Ex LR Chief Technician) |
Hi Matt,
