![]() | Home > Technical (L405) > front knuckle cracking |
woodyrvf750 Member Since: 10 Jul 2023 Location: Stratford Upon Avon Posts: 38 ![]() ![]() |
Hi all, I've got a very small YouTube channel called 'Woody's Secret Garage' and would like to do some brief interviews with owners of 2017 and later cars who have had this issue.
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7987 ![]() ![]() ![]() |
There isn’t a recall at all for any L494, so that might also be an avenue, ie not just 2017 onwards….
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8096 ![]() ![]() ![]() |
Whilst it might work, the major down side is that it would likely void your insurance in the event of a failure. |
FHForgeDB Member Since: 11 Jun 2025 Location: Donnybrook Posts: 2 ![]() ![]() ![]() |
Yep - can't argue with that. There's probably not an engineer in the world that would sign off on it but there was probably a dozen that looked the original knuckle and gave it the nod |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8755 ![]() ![]() ![]() |
I've seen a lot of pictures of broken knuckles and it is obvious to me that the gap between the two sides of the pinch bolt is only about half the size of mine (which is too old to be recalled)
Could be on to something there Pete…. Who knows the torque setting?….. my neighbor had a slight crack in his and it failed when they were taking the bolt out he said…. Perhaps they should have put a spacer in…..
This is from the TOPIX instruction for carrying out the recall. It mentions 40nm + 30 degrees.
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2742 ![]() ![]() |
The gap will reduce once the casting is cracked.
Definitely seen several with just a small crack, no detached part, and the pinch bolt gap appears smaller... Pete
Extol Member Since: 13 Jan 2024 Location: London Posts: 13 ![]() ![]() ![]() |
Thanks Woody, for the new torque setting. I did not have that to hand when I did this last year. Which I torqued up to 45Nm (went with the feel of the hand sort of thing). I got one more to do this summer. |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1852 ![]() ![]() |
4RRS Member Since: 13 Apr 2022 Location: Crudgington Posts: 403 ![]() ![]() ![]() |
I guess us L494 owners are in for a long wait....
… and today JLR have requested my L405 2017 knuckle for ‘destructive testing’ following the serious safety defect I raised with VOSA. Tiny baby steps in the right direction, perhaps. |
JamboM3 Member Since: 28 Jul 2021 Location: Berkshire Posts: 258 ![]() ![]() ![]() |
That’s positive!
