Home > Technical (L405) > Autophix 7310 Code Reader - the JLR Compatible Version.
Page 2 of 3 <123>
chris_read
England 2009 Range Rover Vogue TDV8 Stornoway Grey
I bought an Autotel AP200 for my 2017 (but MY2018) Jaguar F Pace and it wouldn’t work as it only covered up to 2017 so I returned it. This was despite asking the seller if it would work on my car, which they claimed would be ok, therefore I can say from personal experience that it doesn’t work with all JLR cars. 2017 Jaguar F Pace 25t Portfolio - still part of the JLR family 😀
2009 3.6 V8 (MY2010) - my first ever diesel! - now also gone Sad
2004 4.4 V8 Petrol Vogue - now gone
Post #719161 4th Jun 2025 6:56pm
Kot
Glad I dont have an F pace or a Disco 3 then Laughing 2018 SE SDV8 4.4 Byron Blue
Post #719163 4th Jun 2025 7:23pm
chris_read
You asked for evidence to back up a claim so I provided it. There’s no need to be deliberately antagonistic with comments which are not in the slightest amusing. 2017 Jaguar F Pace 25t Portfolio - still part of the JLR family 😀
Post #719164 4th Jun 2025 7:29pm
Kot
You can find posts for and against
Disco3
https://www.disco3.co.uk/forum/topic192402.html
You can find similar on Fpace forum and probably every other forum. 2018 SE SDV8 4.4 Byron Blue
Post #719189 5th Jun 2025 11:15am
detgnome
United Kingdom 2013 Range Rover Vogue SE SDV8 Carpathian Grey
Got the Autophix 7310 from AliExpress, somewhat oddly it was from a UK supplier. I paid £38, but the price does seem to fluctuate (£50 when I post this). You can update to the latest info by PC/Laptop and USB so I wouldn't be too concerned about seeing the numerous 2024 versions on AliExpress. The latest firmware I installed when I got it was dated May 2025.
https://www.aliexpress.com/item/1005007585...f19cscouz9
Post #719666 12th Jun 2025 6:18pm
Stuart-
How do you find yours? Have you had chance to do much with it? 2017 4.4 SDV8 Autobiography in black
2018 D300 SE Velar in champagne
2006 Bentley Flying Spur in silver
Post #719704 13th Jun 2025 2:38pm
detgnome
So far so good. I've managed to reset the service counter post an oil change this morning and have also seen a multitude (ok not that many, but still more than 10) of codes that are registered. I have a suspicion that a battery change may be imminent - battery tester ordered.
As above, purchase and update was easy. Without trying the other options it's difficult to know what's better, but at less than £50 it's a 90% option vs the Gap IID tool.
Post #719725 13th Jun 2025 8:53pm
noone
United States
Can this one:
Read the transmission oil temp?
Set to extended height air suspension?
I have an old ELM 327 OBD2 reader that seems to work reading codes and temps, depending on what iOS app you download. I wonder if this Autophix is similar or better than what I have now.
It's only $38 USD so I may take the plunge.
I have both a L405 and L460, the Gap IID tool seems expensive to have to buy two licenses and then have to pay extra on top to,maybe get extra add ons like remember last auto stop setting or turn on euro lights?
Thx in advance. 2023 L460 Range Rover SE P400
2019 L405 Range Rover ATB LWB
Post #719907 17th Jun 2025 3:39am
detgnome
I've checked and it can read the transmission temp. I had a look in the JLR special functions menu and it does have a section for the air suspension, including options such as deflating the entire system, calibration and tight tolerance mode, but I didn't see anything for extended height. There is an option to go into build/manufacturing mode, but other than throwing up some errors that I had to reset, it didn't seem to do anything else.
Post #719979 18th Jun 2025 12:13pm
noone
United States
Thank you. Seems like a good gamble for $38.00 USD. On it. 2023 L460 Range Rover SE P400
Post #719980 18th Jun 2025 12:22pm
noone
United States
I just received mine and I looked about 10 times at the 'Datastream' section and was not able to see any other temp readings than Engine Oil Temp and Engine Coolant Temp and Ambient Air Temp. I updated it to the latest May 2025 firmware. Do you mind taking a picture of your Transmission Temp? Maybe I am missing it? This is the main reason I needed this so I can change the transmission oil. 2023 L460 Range Rover SE P400
Post #720385 26th Jun 2025 2:58am
detgnome
Step by step below - You can find it in the JLR section. Note the transmission temp is on the very last page of the datastream so you have to scroll all the way through.
Post #720408 26th Jun 2025 2:04pm
noone
United States
THANK YOU!!!!
I am now 110% satisfied with this! 2023 L460 Range Rover SE P400
Post #720413 26th Jun 2025 5:01pm
noone
United States
Do you happen to have deployable side steps on your L405? If so, wondering if your Autophix shows a 'RBM' ECU. Mine, does not, and I think it's because the module got removed on my car at some point so I want to verify. Thx in advance. 2023 L460 Range Rover SE P400
Post #721697 22nd Jul 2025 1:41am
noone
United States
Post #721698 22nd Jul 2025 1:42am
Page 2 of 3 <123>
