![]() | Home > Technical (L405) > Autophix 7310 Code Reader - the JLR Compatible Version. |
chris_read Member Since: 26 Feb 2012 Location: Louth, Lincolnshire Posts: 476 ![]() ![]() ![]() |
I bought an Autotel AP200 for my 2017 (but MY2018) Jaguar F Pace and it wouldn’t work as it only covered up to 2017 so I returned it. This was despite asking the seller if it would work on my car, which they claimed would be ok, therefore I can say from personal experience that it doesn’t work with all JLR cars. 2017 Jaguar F Pace 25t Portfolio - still part of the JLR family 😀
Kot Member Since: 10 Mar 2021 Location: Broadland Posts: 1384 ![]() ![]() |
Glad I dont have an F pace or a Disco 3 then |
You asked for evidence to back up a claim so I provided it. There’s no need to be deliberately antagonistic with comments which are not in the slightest amusing. 2017 Jaguar F Pace 25t Portfolio - still part of the JLR family 😀
You can find posts for and against
detgnome Member Since: 21 May 2025 Location: Kent Posts: 11 ![]() ![]() ![]() |
Got the Autophix 7310 from AliExpress, somewhat oddly it was from a UK supplier. I paid £38, but the price does seem to fluctuate (£50 when I post this). You can update to the latest info by PC/Laptop and USB so I wouldn't be too concerned about seeing the numerous 2024 versions on AliExpress. The latest firmware I installed when I got it was dated May 2025.
So far so good. I've managed to reset the service counter post an oil change this morning and have also seen a multitude (ok not that many, but still more than 10) of codes that are registered. I have a suspicion that a battery change may be imminent - battery tester ordered.
noone Member Since: 05 Apr 2025 Location: Florida Posts: 58 ![]() ![]() |
Can this one:
I've checked and it can read the transmission temp. I had a look in the JLR special functions menu and it does have a section for the air suspension, including options such as deflating the entire system, calibration and tight tolerance mode, but I didn't see anything for extended height. There is an option to go into build/manufacturing mode, but other than throwing up some errors that I had to reset, it didn't seem to do anything else. |
Thank you. Seems like a good gamble for $38.00 USD. On it. 2023 L460 Range Rover SE P400
I just received mine and I looked about 10 times at the 'Datastream' section and was not able to see any other temp readings than Engine Oil Temp and Engine Coolant Temp and Ambient Air Temp. I updated it to the latest May 2025 firmware. Do you mind taking a picture of your Transmission Temp? Maybe I am missing it? This is the main reason I needed this so I can change the transmission oil. 2023 L460 Range Rover SE P400 2019 L405 Range Rover ATB LWB |
Step by step below - You can find it in the JLR section. Note the transmission temp is on the very last page of the datastream so you have to scroll all the way through.
THANK YOU!!!!
