Home > General > What Did You Do In Your Full Fat Today
Page 385 of 385 <123 ... 383384385
Gremlin500
Today I did my annual front knuckle penetration dye crack test on my L405 (fortunately without drama Laughing ) and did a mini-service on the front brake calipers at the same time, cleaned them up took out all the pads & pins and applied aluminium grease ready for Winter. The 2 Y.O. bleed nipples were starting to rust, so cleaned those & applied Lanoguard grease with an artists’ brush, will replace them next Spring when I change the pads. V6 Vogue - “Less is More” - less to go wrong!
Post #723711 31st Aug 2025 6:27pm
tspd
Not really a single day but a quick story here with some photos Smile
https://www.fullfatrr.com/forum/post723902.html#723902 L322 2007 S/C 4.2L (first full fat)
135k miles and counting
Buckingham Blue
Post #723903 3rd Sep 2025 10:25pm
hmallett
United Kingdom 2013 Range Rover Autobiography SDV8 Firenze Red
Today I returned from an enjoyable week long trip in the caravan, towing it across the country - a task which the car performed faultlessly*, like every other family trip**
* Except for a park brake motor failure, when the bark brake motors where replaced recently as a precaution
** 5 trips ago, the rear ACE pipes failed, 4 trips ago we had to take a different car as the RR was in the garage getting new ACE pipes, 3 trips ago an earth point failed, 2 trips ago we had to take a different car as the RR was in the garage getting the earth point repaired, 1 trip ago we successfully completed a trip without incident.
Post #724145 7th Sep 2025 10:15pm
Alex1976
United Kingdom 2016 Range Rover Vogue TDV6 Santorini Black
I gave the RR its usual pre-winter deep clean. Clay bar, polish and then wax. Makes it easier to keep clean when the winter arrives and the weather is grim. Couldn’t resist getting a photo once done.
Post #724148 7th Sep 2025 10:47pm
