![]() | Home > Technical (L405) > front knuckle cracking |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8808 ![]() ![]() ![]() |
If you want to go the cheap Chinese route then buy them from Rangeroverworlds suppliers, loads on AliExpress starting at £200...
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1865 ![]() ![]() |
They look identical to the Britpart offerings... |
Extol Member Since: 13 Jan 2024 Location: London Posts: 16 ![]() ![]() ![]() |
Now I have done both my 2016 L405 knuckles, few things I did do/change.
Hope this is any help |
chugga90 Member Since: 24 Jul 2015 Location: Chilterns Posts: 158 ![]() ![]() |
Stainless steel and alloy do not work well together. |
Thank you, and much appreciate the advise, I thought my protective coating will stop the water getting in. I could be wrong, but I shall keep an eye. |
When using dissimilar metals you need some form of barrier, not a coating done after assembly... I use Tef Gel, used widely in the marine industry.... |
