Home > Technical (L405) > front knuckle cracking
Page 55 of 55 <123 ... 535455
4RRS
United Kingdom 2016 Range Rover SVAutobiography SDV8 Corris Grey
Seems strange that RRW are using now-superceded JLR oem part numbers as a reference.
Little praise can be handed to Land Rover for this latest major fiasco, however on the flip side I think I'd prefer a part with traceability and knowing it has been designed (and re-designed) with proper testing rather than an unknown part from a probable Chinese supplier that hasn't got the support of a multi national behind it for when things go wrong.
Lets not even get onto the wheel bearing and its origin!
Just by two-penneth worth L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division.
Post #724333 11th Sep 2025 12:22pm
If you want to go the cheap Chinese route then buy them from Rangeroverworlds suppliers, loads on AliExpress starting at £200...
If you read the blurb from RRW , it's very well laid out but actually tells you little and promises even less... Pete
-Click here for Thread-
Post #724343 11th Sep 2025 3:19pm
Mikey
They look identical to the Britpart offerings...
Post #724366 11th Sep 2025 7:47pm
Extol
United Kingdom 2016 Range Rover Autobiography SDV8 Carpathian Grey
Now I have done both my 2016 L405 knuckles, few things I did do/change.
First bought Genuine LR Knuckles with a newer date of manufacture (2023) hoping that they have improved the quality (I know that's big ask).
Then replaced the metal bolt and the nut with a stainless steel.
Then fit a larger diameter stainless steel washers to increase the pinch surface area, so more force will get distributed at the top. tightened to 45Nm(new figure in TOPIx) NOT the 60Nm as in the old workshop manual.
Then at the end a good coating of lacquer spray to stop any water getting inside the joint. ( this will only extend the deterioration buy few months).
[/list]
Post #724465 13th Sep 2025 11:38am
Extol
Hope this is any help
Post #724466 13th Sep 2025 11:38am
chugga90
Stainless steel and alloy do not work well together.
Post #724472 13th Sep 2025 3:26pm
Extol
Thank you, and much appreciate the advise, I thought my protective coating will stop the water getting in. I could be wrong, but I shall keep an eye.
Post #724510 14th Sep 2025 9:13am
When using dissimilar metals you need some form of barrier, not a coating done after assembly... I use Tef Gel, used widely in the marine industry.... Thumbs Up
https://www.paintmarine.co.uk/tikal-tef-ge...eWwIUmdt4E Pete
Post #724516 14th Sep 2025 10:28am
