Home > Maintenance & Mods (L322) > Brighter reverse lights?
Page 1 of 3 123>
AMV
2011 Range Rover Vogue TDV8 Santorini Black
Gents,
has anybody fitted aftermarket bulbs for the reverse light? Maybe some error-free leds? Rolling Eyes
And what bulb do we have by the way? Very Happy
Thanks for your input Thumbs Up Santorini Black RR Vogue 4.4 TDV8
Post #77887 27th Aug 2011 11:00pm
they are crappy 6 watt jobbys and dont give much light...i've replaced mine with smd's but although the light is now whiter its still not that much brighter due to the size restriction of the new bulbs..i do get an error as my install is only temporary until i think of something else..
Post #77898 28th Aug 2011 8:46am
If you need a bit more light at times switch the rear foglights on when reversing.
Post #77899 28th Aug 2011 8:59am
good tip NDFI and maybe touching the brakes lights as well... Wink
Post #77900 28th Aug 2011 9:03am
dan_uk_1984
If you want more light then you could fit a higher wattage bulb - 10 watt etc. The wiring would take a small increase. You would have to ensure you don't leave it in reverse for extended periods or you could risk burning the lense.
LED's are the way to go if you want a whiter light, but certainly not a brighter
Post #77901 28th Aug 2011 9:03am
couldnt find a larger wattage bulb with the same fittings when i looked dan, mind you i didnt look much cos i swung over to the smd's more or less straight away..
Post #77902 28th Aug 2011 9:21am
daveo
i think you will find that they are halogen bulbs hence the funny fitment, so i think you wont get any brighter bulb with out a mod of some sort, V8 facelift Range Rover Autobiography 22" wheels.
Post #77907 28th Aug 2011 9:46am
If its for night lighting why not install some infra-red bulbs, the reversing camera can then pick up objects better can it not, aka nightvision??
Post #77908 28th Aug 2011 9:58am
only if you have a reverse camera.. Wink
Post #77909 28th Aug 2011 10:09am
AMV
And what fitment do we have? Smile I've seen many bright bulbs which are claimed to be "xenon like". I thought the camera had IR lighting? Rolling Eyes Santorini Black RR Vogue 4.4 TDV8
Post #77911 28th Aug 2011 10:51am
ahh you referring to the pauper FFRR edition Wink Mr. Green Laughing
PS only kidding!
Post #77912 28th Aug 2011 10:54am
these are the ones i fitted..
Post #77913 28th Aug 2011 10:57am
PS only kidding!
Laughing
Post #77914 28th Aug 2011 10:58am
AMV
Scarey, do they trigger the "check lights" warning? Or you've added some resistors? Thumbs Up and they are "straight" or "curved"? Santorini Black RR Vogue 4.4 TDV8
Post #77916 28th Aug 2011 11:05am
you do get a 'check bulb warning' and i haven't put resisters in-line yet..
straight /curved ?
Post #77924 28th Aug 2011 12:10pm
Page 1 of 3 123>
