![]() | Home > Maintenance & Mods (L322) > Brighter reverse lights? |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35885
they are crappy 6 watt jobbys and dont give much light...i've replaced mine with smd's but although the light is now whiter its still not that much brighter due to the size restriction of the new bulbs..i do get an error as my install is only temporary until i think of something else.. |
| nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3989
If you need a bit more light at times switch the rear foglights on when reversing. |
good tip NDFI and maybe touching the brakes lights as well... |
| dan_uk_1984 Member Since: 12 Nov 2008 Location: Bude, Cornwall Posts: 4014
If you want more light then you could fit a higher wattage bulb - 10 watt etc. The wiring would take a small increase. You would have to ensure you don't leave it in reverse for extended periods or you could risk burning the lense.
couldnt find a larger wattage bulb with the same fittings when i looked dan, mind you i didnt look much cos i swung over to the smd's more or less straight away.. |
| daveo Member Since: 21 Oct 2009 Location: london Posts: 2307
i think you will find that they are halogen bulbs hence the funny fitment, so i think you wont get any brighter bulb with out a mod of some sort, V8 facelift Range Rover Autobiography 22" wheels.
| kingpleb Member Since: 07 Jun 2011 Location: Maybe here. Maybe there, I get everywhere! Posts: 8455
If its for night lighting why not install some infra-red bulbs, the reversing camera can then pick up objects better can it not, aka nightvision?? |
only if you have a reverse camera.. |
| AMV Member Since: 09 Mar 2011 Location: EU Posts: 152
And what fitment do we have? |
ahh you referring to the pauper FFRR edition PS only kidding! |
these are the ones i fitted..
Scarey, do they trigger the "check lights" warning? Or you've added some resistors? |
you do get a 'check bulb warning' and i haven't put resisters in-line yet..
| All times are GMT |
