Home > My Range Rover > How to modernise a 2003 Vogue V8
Page 2 of 3 <123>
rich89
United Kingdom 2010 Range Rover Autobiography 5.0 SC V8 Causeway Grey
Thanks.
Need to get it serviced/health checked first.
How do you reset the mpg trip?
Post #188146 13th May 2013 10:12pm
Bushy513
United Kingdom 2003 Range Rover Vogue Td6 Monte Carlo Blue
On the computer screen roll the selector over to the trip you want to reset then push in the button and select reset Bushy
2003 RR Vogue Monté Carlo Blue
Post #188147 13th May 2013 10:23pm
Budgie
First off I would get it serviced, if not already done, and have the gearbox oil & filter changed if it's not recorded in the service record.
You mention the seat, if the foam is flat then you can get a new foam base for it that's relatively cheap and you can bring up the leather again with some Scuff Master, just choose the correct colour of your leather and they supply a 65ml kit what work wonders.
I used it on my Shogun and you couldn't see where it had warn when it was cleaned, re-coloured and fed.
My plans with my 2003 V8 is to get everything working as it should and add a few creature comforts, I'm in the process of fitting Bluetooth and have already fitted a digital TV tuner.
This week I put a clay bar over the paintwork, polished & waxed it, what a difference!
I've been looking at 2006 rear lights (white + red) and will wait for some to come along at the right price.
Oh and a sound investment is the IID Tool, great for reading & clearing ECU faults, altering parameters and other settings like making your full beam units act as daylight running lights. Wink
Post #188155 13th May 2013 11:12pm
Rich86
United Kingdom 2009 Range Rover Vogue TDV8 Nara Bronze
Budgie, I'm interested in the IID tool but want to buy the right one of course.
Would it clear and reset messages such as air suspension inactive?
I need one that can do this really. 2009 Vogue TDV8 Nara Bronze
2002 Vogue V8 Zambezi Silver
1986 90 Pick up Deep Bronze Green
1978 Series III SWB Deep Bronze Green
Post #188159 14th May 2013 6:25am
TheAllSeeingPie
United Kingdom 2007 Range Rover Supercharged Supercharged Java Black
IID can clear all faults, Censored about with suspension settings and faff around with the car config. They are bloody brilliant and practically pay for themselves when dealers say "we'll plug in a test book and that'll be 1 hours labour". The look on their face when you say it's not necessary and give them the fault codes is great. Also with access to RAVE (link in the Wiki) you can translate the fault code to a problem and usually sort it yourself. It's never good to pay for an hours labour when you're just changing fuses or fixing a loose connection. Oh and if you haven't had the "pleasure" of a main dealer yet, an hours labour is £100+, so find a decent local Indy Thumbs Up
07 Supercharged - Still breaking her in!
Boot soundproofing part 1 - http://www.fullfatrr.com/forum/topic15612.html
Custom exhaust - http://www.fullfatrr.com/forum/topic15296.html
18" wheels for Brembo equipped cars - http://www.fullfatrr.com/forum/topic15052.html
Post #188161 14th May 2013 7:00am
Bushy513
I believe you can get rid of the air suspension inactive fault code, as long as there isn't a genuine fault, by simply turning the steering wheel from lock to lock to reset the sensors. You tube it, powerful uk posted a video about this. Bushy
Post #188162 14th May 2013 7:06am
Rich86
Morning guys,
I think there's an intermittent problem with the AS but when the car went into for a service recently they cleared it and it worked afterwards.
I've tried the steering lock left to right and to no avail unfortunately.
So I really need to know which IID tool is the best for general stuff and one that will also clear AS faults like this one. I'm guessing if the dealer was able to clear then I wil be able to with the right IID?
Cheers
Post #188163 14th May 2013 7:16am
markcartlidge
United Kingdom 2002 Range Rover Vogue 4.4 V8 Java Black
My IID Tool arrived yesterday. Great piece of kit but if you have dodgy pixels it may be hard work. I made some config changes, turned off steering wheel retraction, turned on auto lock function. Cleared all faults and will see which have returned today.
Your lower cost options are:-
GAP IID Tool
Bearmach Hawkeye
RSw All Comms
Bridpart Lynx Diagnostics
My 2nd choice was the All comms as the lynx is new and there is little feedback out there on it.
Post #188186 14th May 2013 8:46am
Budgie
This will tell you what it can do for your year of FF: http://www.gap-diagnostic.com/products/iidtool.html
This is where I got mine from: http://www.island-4x4.co.uk/integrated-int...-6425.html
Post #188211 14th May 2013 12:03pm
A1GSS
Thumbs Up Island 4x4 was the cheapest for me too. Graham
____
Gone: 10MY L320 RR Sport HSE, Ipanema Sand
Gone: 20MY Jaguar iPace HSE, Silicon Silver
Gone: 17MY RR Evoque SE Tech, Loire Blue
Gone: 08MY Discovery 3 XS, Stornoway Grey
Gone: 07MY FFRR TDV8 Vogue, Stornoway Grey
Post #188212 14th May 2013 12:04pm
Rich86
It says that full fuNctionality on all systems wil be available by autumn 2013.
Does this mean its best to wait for the update?
Post #188316 14th May 2013 8:01pm
Budgie
No, you can plug the IID Tool into a USB port on your PC and update the software that way. So you'll still get the latest updates but have the pleasure of using it in the meantime. Thumbs Up
Post #188349 14th May 2013 10:30pm
Rich86
Well the one thing I really need to be able to do is clear the EASN fault.
If it will do that then I'll buy it.
Post #188385 15th May 2013 8:15am
A1GSS
Yes, for sure it will do that. Lots of EAS functionality included. I can email you a copy of the manual if you like. Graham
____
Post #188386 15th May 2013 8:23am
It will certainly tell you what the fault is so you can repair it... Thumbs Up
Post #188387 15th May 2013 8:24am
Page 2 of 3 <123>
