Home > Technical (L322) > How to Find Top Dead Center TDV8 |
RP123 Member Since: 06 Jul 2014 Location: Highlands Posts: 187 |
Possible alarm issue? - Try a different key and or try the good old battery reset - (disconnect battery etc.)
14th Dec 2016 4:32pm |
hamlet Member Since: 18 Nov 2016 Location: Kildare Posts: 294 |
P1623 ECM Security Code Fault.
14th Dec 2016 4:52pm |
theanswers Member Since: 30 Jul 2012 Location: Ireland Posts: 302 |
I tired the physical battery reset method! So no joy there.
14th Dec 2016 4:56pm |
Yes. The steering lock clicks! |
14th Dec 2016 7:22pm |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 |
That sounds like the same issue I had with my 04 although the actual electronic components maybe different. Mine would crank but not start and the only way around it was to use a faultmate or T4 to teach the engine ECU the immobiliser code. This happens if I leave my battery disconnected as when I did my transmission.
15th Dec 2016 7:42am |
The problem could be something as you describe, as it is stating an identification mis-match. However, I can't understand how this come just happen all of a sudden. I have access to the Land Rover Dealer software which I purchased years ago for an old car. This could do it, I'd just be afraid of doing something wrong! |
15th Dec 2016 11:53am |
I had the same issue with a 2006 BMW E61 520d, a relay decided to give up the ghost so communication was lost between some brains, it has a rolling code so after replacing the relay it has to be recoded (ex BMW tech with a laptop round the back of my house). Sounds like you may have a similar issue, mine would fire straight away 9 times out of 10 but then as the relay got worse it one day decided not to fire at all and had to be recoded. I can give you his number if you want, he's based in Kildare so not sure if he's much good to you but he might be able to give you a bit of info or point you in the right direction. |
15th Dec 2016 1:15pm |
The EWS immobiliser ended in mid 2005 according to the link below which is for the faultmate manufacturer and i can't find anything about reprogramming the link on the later models in my vehicle explorer software but that is not to say you can't do it or needs to be done. The SM131 module i think is what you purchase to go with your faultmate to enable you to talk to the systems listed.
15th Dec 2016 9:37pm |
Hey Everyone.
16th Dec 2016 1:00am |
Hope you get to the bottom of it, you deserve if after all the work.
16th Dec 2016 1:14am |
rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119 |
Sounds like you're on to something.
16th Dec 2016 11:04am |
The row DS2 (Front) doesn't seem to be correct. This again leads to a damaged loom.
16th Dec 2016 1:48pm |
I had a good look today lads. Couldn't see anything amiss. Checked for damaged wires and nothing I could see. I also checked all the fuses in the engine bay. I've left the battery in, so lets see if she goes flat.
17th Dec 2016 8:09pm |
Have a read here, this is what I was telling you about before when I was talking about the VSS being related to misfires, different vehicles I know, but worth a read.
17th Dec 2016 8:58pm |
