Home > Technical (L322) > Range rover chassis measurements
texpis
England 2002 Range Rover HSE 4.4 V8 Alveston Red
Hi all
I have had a mishap in my 2002 mk 3 range rover the insurance has written it off and I have bought it back. I would like the measurements of the chassis/body to see if it requires jigging. Does anyone have access to such information, quite happy to pay for them just don't know where to look.
Thanks Mick
Post #189626 21st May 2013 4:07pm
the first thing that springs to mind is RAVE, anything on there ?. ... - .- -.
Post #189627 21st May 2013 4:14pm
texpis
looked in there cant see anything.
Mick
Post #189631 21st May 2013 4:42pm
aah, ok..
maybe Craig at CTC or Dan at duckworths, but it does sound pretty specialist to me..... ... - .- -.
Post #189632 21st May 2013 4:44pm
If you take pictures and give instructions of the measurements you want, I'd be happy to do a bit of measuring..... .
Post #189636 21st May 2013 5:34pm
texpis
Cheers for the offer joe will do some tomorrow
Mick
Post #189645 21st May 2013 6:35pm
texpis
Hi Joe as you can see the damage is more at the top haven't stripped it yet but suspect the turret ant the top could have moved in a couple of CMs. could you measure between the turret bolts that hold the suspension air bags for me please.
Uploaded with ImageShack.us
Post #189673 21st May 2013 8:43pm
RRPhil
I think that the information you’re after is in the Service Procedures section of RAVE
Phil
Post #189675 21st May 2013 8:58pm
texpis
Aha thanks for that Phil looked at rave but didn't look there Rolling Eyes
Mick
Post #189678 21st May 2013 9:15pm
Well, just out of interest I went out to have a measure on "C"
The closest I could get to 1172.6mm was to measure from the outside of the thread on the two most forward threads on the turret, the one on the LHS being the "earth" connection for a jump start and the equivalent on the other side, which gave 1171mm.
On my car (and from your picture) the "outboard fixing" as in dictated in the diagram is not a bolt but the pointy thing which locates the upper part of the suspension strut. This measures much wider ?
Car looks very sad, even more so as it is a red one Wink Big Cry .
Post #189684 21st May 2013 9:36pm
Mick, it doesn't look hard enough to have moved the strutt top! Normally the cost of parts is the big killer when you hit the front corner...
I have all the parts to repair your car if of interest pal? PM me if of interest Thumbs Up
Craig
Post #189687 21st May 2013 9:39pm
texpis
Hi joe yes it looks a bit sad hopefully will get it sorted garage recon 14k to repair Shocked
Craig pm sent
Mick
Post #189695 21st May 2013 10:08pm
TheAllSeeingPie
United Kingdom 2007 Range Rover Supercharged Supercharged Java Black
At £14k to repair you're probably in "break it up and buy a facelift" territory unfortunately Sad
07 Supercharged - Still breaking her in!
Boot soundproofing part 1 - http://www.fullfatrr.com/forum/topic15612.html
Custom exhaust - http://www.fullfatrr.com/forum/topic15296.html
18" wheels for Brembo equipped cars - http://www.fullfatrr.com/forum/topic15052.html
Post #189731 22nd May 2013 7:44am
RRPhils post needs to go in the WIKI....
Post #189750 22nd May 2013 8:30am
Is there other damage we can't see in the photos? That really does not look like 14k worth of damage. Previously..
Post #189764 22nd May 2013 8:50am
