|  | Home > Technical (L322) > Range rover chassis measurements |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35883   | the first thing that springs to mind is RAVE, anything on there ?. ... - .- -.
| texpis Member Since: 29 Nov 2010 Location: Stockton-on-tees Posts: 53     | looked in there cant see anything.
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35883   | aah, ok..
| Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6434   | If you take pictures and give instructions of the measurements you want, I'd be happy to do a bit of measuring..... .
| texpis Member Since: 29 Nov 2010 Location: Stockton-on-tees Posts: 53     | Cheers for the offer joe will do some tomorrow
| texpis Member Since: 29 Nov 2010 Location: Stockton-on-tees Posts: 53     | Hi Joe as you can see the damage is more at the top haven't stripped it yet but suspect the turret ant the top could have moved in a couple of CMs. could you measure between the turret bolts that hold the suspension air bags for me please.
| RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1044   | I think that the information you’re after is in the Service Procedures section of RAVE
| texpis Member Since: 29 Nov 2010 Location: Stockton-on-tees Posts: 53     | Aha thanks for that Phil looked at rave but didn't look there   | ||
| Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6434   | Well, just out of interest I went out to have a measure on "C"
| Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16403     | Mick, it doesn't look hard enough to have moved the strutt top! Normally the cost of parts is the big killer when you hit the front corner...
| texpis Member Since: 29 Nov 2010 Location: Stockton-on-tees Posts: 53     | Hi joe yes it looks a bit sad hopefully will get it sorted garage recon 14k to repair    | ||
| TheAllSeeingPie Member Since: 18 Apr 2012 Location: Leeds Posts: 848     | At £14k to repair you're probably in "break it up and buy a facelift" territory unfortunately  | ||
| Gazellio @ Prestige Cars Member Since: 22 Jan 2010 Location: Chilterns, UK Posts: 11309     | RRPhils post needs to go in the WIKI.... | ||
| Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3700   | Is there other damage we can't see in the photos? That really does not look like 14k worth of damage. Previously..
| Posting Rules
