![]() | Home > Technical (L322) > Range rover chassis measurements |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35686 ![]() ![]() |
the first thing that springs to mind is RAVE, anything on there ?. ... - .- -.
texpis Member Since: 29 Nov 2010 Location: Stockton-on-tees Posts: 53 ![]() ![]() ![]() |
looked in there cant see anything.
aah, ok..
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6419 ![]() ![]() |
If you take pictures and give instructions of the measurements you want, I'd be happy to do a bit of measuring..... .
Cheers for the offer joe will do some tomorrow
Hi Joe as you can see the damage is more at the top haven't stripped it yet but suspect the turret ant the top could have moved in a couple of CMs. could you measure between the turret bolts that hold the suspension air bags for me please.
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1004 ![]() ![]() |
I think that the information you’re after is in the Service Procedures section of RAVE
Aha thanks for that Phil looked at rave but didn't look there |
Well, just out of interest I went out to have a measure on "C"
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16342 ![]() ![]() ![]() |
Mick, it doesn't look hard enough to have moved the strutt top! Normally the cost of parts is the big killer when you hit the front corner...
Hi joe yes it looks a bit sad hopefully will get it sorted garage recon 14k to repair |
TheAllSeeingPie Member Since: 18 Apr 2012 Location: Leeds Posts: 848 ![]() ![]() ![]() |
At £14k to repair you're probably in "break it up and buy a facelift" territory unfortunately |
RRPhils post needs to go in the WIKI.... |
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3697 ![]() ![]() |
Is there other damage we can't see in the photos? That really does not look like 14k worth of damage. Previously..
