Home > Technical (L322) > Help on diesel leak
Page 1 of 3 123>
Johnsd1v8
United Kingdom 2004 Range Rover Autobiography Td6 Zambezi Silver
Help on diesel leak
So i need advise/help on a diesel leak i found last night while looking underneath my td6 checking ball joints etc i think its the pump thats on the engine just near the alternator its fairly wet there i cant really say how bad its leaking due to not being able to see it or where on the pump its comming from but there was a puddle of fuel in the under tray ive done some reading on here about the high and low pressure side and im not expericing any power loss on ecceloration or bad starting so any advice on what i should do next is very gratefull i.e could it just be a split pipe or the pump its self and how hard is it to remove the bits to get to the pump thanks people
Post #468832 16th Feb 2018 8:38am
olliecat2
United Kingdom 2004 Range Rover Vogue Td6 Java Black
Can you tell if your getting a leak when the engine is running .When mine was leaking diesel it was only on start up on cold days and it was due to cabin preheater system not igniting and hence unburnt diesel was overflowing from burner unit. I had it blanked off and had no problems with spillage all over driveway since.
Post #468902 16th Feb 2018 4:21pm
Johnsd1v8
Pretty sure my fbh works i can hear it like a mini jet engine 😂 thats not to say its not leaking though its wet on the pump thats all i can see when its running hopefully ill get a better look tonight
Post #468905 16th Feb 2018 5:10pm
Johnsd1v8
So im looking at this now the dripping pump stopped dripping after 5-8 mins of engine running and the small pipe at the front of the pump is a little loose it goes to the filter but there is a T piece which goes to the fbh i think
Post #468910 16th Feb 2018 6:04pm
Johnsd1v8
Post #468911 16th Feb 2018 6:05pm
holidaychicken
I have the exact same problem I discovered yesterday but haven’t had chance to investigate further. The one I’m working on is a 2006 TD6 M57 and also has a limp mode at high revs up hill and P0046 code. Also interested to see where your leak is as mine looks the same.
Post #468964 17th Feb 2018 1:41am
Johnsd1v8
Well ive just checked mine again this morn turns out it wasent je jubilee clip itsdripping from below that where the plate has 4 bolts some where there but again only on start up
Post #468967 17th Feb 2018 5:27am
holidaychicken
I’ll let you know if I find mine, the initial thoughts are high pressure pump.
Post #468986 17th Feb 2018 10:06am
Johnsd1v8
Found a place in doncaster called maltings off road they can sell me a pump for £245 does this sound abit cheap the guy said they are refurbed by lucas but im still unsure as to why it only leaks on start up for 5 or so mins then stops leaking untill the next mornings start up
Post #469208 18th Feb 2018 6:48pm
Paul thornton
It's quite a common fault, mines starting to go the same way.
The pump seals can be bought off eBay for around £13 but obviously you've got to remove the pump and strip it to fit them, then get it pressure tested and refit.
I've got another pump for mine which I'm going to fit when I can be bothered.
Post #469219 18th Feb 2018 7:15pm
Johnsd1v8
Thats the way im thinking paul untill it starts spuing diesel out ill leave it be ive bought the tool to keep the chain and sprocket in place while i push the pump out i belive it to be a straight forward job and i also have read that the pump is NOT timed so it doesnt matter where the timing is when pump is swapped is that right
Post #469227 18th Feb 2018 7:32pm
holidaychicken
Having a search the Maltings one looks like a good deal
https://www.brit-car.co.uk/product.php/125...ange_rover
https://www.ebay.co.uk/itm/range-rover-td6...2415953861
https://www.lrdirect.com/MSR000010-Pump-Assy-Fuelinj/
Post #469239 18th Feb 2018 8:29pm
Johnsd1v8
My god you could buy 2 and still be cheaper than £1100 does the maltings one seem a little to cheap i dont want to be stuck with a pump thats been refurbed on the cheap
Post #469249 18th Feb 2018 9:31pm
carpcat
United Kingdom 2011 Range Rover Vogue SE TDV8 Santorini Black
Ive used Maltings a few times and they seem very reasonable, particularly for genuine parts. If you sign up on their website to their trade club, you get a certain percentage discount. I think I got about 12% last time, which on top of their competitive prices gives a good deal. Chris
Post #469255 18th Feb 2018 9:56pm
holidaychicken
I think you will be ok, if they are replacing seals which I think are cheap and they are having them tested then they can probably still do a good job, pass on a good price and still make a reasonable profit
Are you sure it’s your pump that’s leaking ?
Post #469270 18th Feb 2018 11:25pm
Page 1 of 3 123>
