![]() | Home > Technical (L322) > Help on diesel leak |
| olliecat2 Member Since: 30 Jan 2018 Location: FLINTSHIRE Posts: 13
Can you tell if your getting a leak when the engine is running .When mine was leaking diesel it was only on start up on cold days and it was due to cabin preheater system not igniting and hence unburnt diesel was overflowing from burner unit. I had it blanked off and had no problems with spillage all over driveway since. |
| Johnsd1v8 Member Since: 06 Jul 2017 Location: Cheshire Posts: 190
Pretty sure my fbh works i can hear it like a mini jet engine 😂 thats not to say its not leaking though its wet on the pump thats all i can see when its running hopefully ill get a better look tonight |
So im looking at this now the dripping pump stopped dripping after 5-8 mins of engine running and the small pipe at the front of the pump is a little loose it goes to the filter but there is a T piece which goes to the fbh i think
| holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086
I have the exact same problem I discovered yesterday but haven’t had chance to investigate further. The one I’m working on is a 2006 TD6 M57 and also has a limp mode at high revs up hill and P0046 code. Also interested to see where your leak is as mine looks the same.
Well ive just checked mine again this morn turns out it wasent je jubilee clip itsdripping from below that where the plate has 4 bolts some where there but again only on start up |
I’ll let you know if I find mine, the initial thoughts are high pressure pump. |
Found a place in doncaster called maltings off road they can sell me a pump for £245 does this sound abit cheap the guy said they are refurbed by lucas but im still unsure as to why it only leaks on start up for 5 or so mins then stops leaking untill the next mornings start up |
| Paul thornton Member Since: 23 Sep 2017 Location: Lancashire Posts: 545
It's quite a common fault, mines starting to go the same way.
Thats the way im thinking paul untill it starts spuing diesel out ill leave it be ive bought the tool to keep the chain and sprocket in place while i push the pump out i belive it to be a straight forward job and i also have read that the pump is NOT timed so it doesnt matter where the timing is when pump is swapped is that right |
Having a search the Maltings one looks like a good deal
My god you could buy 2 and still be cheaper than £1100 does the maltings one seem a little to cheap i dont want to be stuck with a pump thats been refurbed on the cheap |
| carpcat Member Since: 13 Oct 2017 Location: Surrey Posts: 58
Ive used Maltings a few times and they seem very reasonable, particularly for genuine parts. If you sign up on their website to their trade club, you get a certain percentage discount. I think I got about 12% last time, which on top of their competitive prices gives a good deal. Chris |
I think you will be ok, if they are replacing seals which I think are cheap and they are having them tested then they can probably still do a good job, pass on a good price and still make a reasonable profit
| All times are GMT |
