Home > Technical (L322) > 3.6 TDV8 issues following split boost/intercooler hose |
Nick591 Member Since: 04 May 2017 Location: Charfield Posts: 193 |
I tracked down my similar issue eventually to a poor connection between the O/S MAPT sensor and the plug on the loom. Was able after fiddling for ages to increase the clamping on the connector receptacles in the plug. Also, as the sensor pins are tapered, I ensured the plug is fully home on the sensor by holding it there with a small cable tie around the plug and a local vac hose that runs near the sensor. No issues with this now for several months. Previously a 2008MY Tonga Green Vogue SE 3.6 TDV8 |
11th Mar 2019 9:10pm |
MarianaWestminster Member Since: 14 Jun 2018 Location: UK Posts: 593 |
Ok so I have made a smoke generator and checked everywhere for leaks.
14th Mar 2019 7:06pm |
chefkenmore Member Since: 11 Jan 2015 Location: Fearnan perthshire Posts: 699 |
That’ll save the pocket!
14th Mar 2019 8:17pm |
14th Mar 2019 9:58pm |
Had a specialist check out the car. MAF readings all normal so that can be disregarded in the diagnosis.
16th Mar 2019 1:25pm |
Grofus Member Since: 24 Mar 2017 Location: Co Clare Posts: 577 |
It can be done without removing anything. Depends how stiff it is I suppose.
16th Mar 2019 3:45pm |
Thanks Grofus,
17th Mar 2019 7:40pm |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2314 |
Just because the MAF readings are normal doesn't mean they're truthful. Can you start swapping MAFs from another vehicle? |
17th Mar 2019 8:39pm |
So, you have ruled out turbo and hoses, cracked manifold, turbo actuators, map sensors. Trans adaptation reset done.
18th Mar 2019 12:32am |
I have been there believe me on this issue when you talk about losing the will to live! The fault code relates to the boost side of the turbo so the MAF sensors (just next to the air cleaner box) are not involved. You could try swapping the MAPT sensors in the inlet manifolds and see if the fault swaps sides. That's a 10 minute job. One plug and one screw per sensor and just pull them up and out. Also check if the left one (bank A) seems to be crudded up with oil etc. Clean with brake cleaner but don't get cleaner up inside the sensor as you might damage it. If the fault changes to bank B that is the problem. Replacement sensors are about £50 each IIRC. Previously a 2008MY Tonga Green Vogue SE 3.6 TDV8 |
18th Mar 2019 12:41am |
Hmmm. Rereading thread my post may be superfluous. In fact my car did not have the erratic tickover and slow pickup below 2500 rpm you described so I suspect a different root cause. I'll get my coat! Previously a 2008MY Tonga Green Vogue SE 3.6 TDV8 |
18th Mar 2019 12:50am |
You may find error codes are revealed by different diagnostics tool. Like many I bought a GAP BT IID tool and would be lost without it. Previously a 2008MY Tonga Green Vogue SE 3.6 TDV8 |
18th Mar 2019 12:53am |
Ive tried fitting a new maf to replace the one which i thought was reading low but no dice. Tried a combination of the 3 mafs I had to hand and nothing no difference.
21st Mar 2019 4:12pm |
rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119 |
Again, I would check the 90 degree hoses and short rear hoses. The are not shown clearly in this workshop diagram, but the rear is located near the 12 and 90 degree is coloured green along with sections of plastic piping.
21st Mar 2019 10:39pm |
