![]() | Home > Technical (L322) > 3.6 TDV8 issues following split boost/intercooler hose |
Nick591 Member Since: 04 May 2017 Location: Seaton Dalaval Posts: 193 ![]() ![]() |
I tracked down my similar issue eventually to a poor connection between the O/S MAPT sensor and the plug on the loom. Was able after fiddling for ages to increase the clamping on the connector receptacles in the plug. Also, as the sensor pins are tapered, I ensured the plug is fully home on the sensor by holding it there with a small cable tie around the plug and a local vac hose that runs near the sensor. No issues with this now for several months. Previously a 2008MY Tonga Green Vogue SE 3.6 TDV8 |
MarianaWestminster Member Since: 14 Jun 2018 Location: UK Posts: 739 ![]() ![]() |
Ok so I have made a smoke generator and checked everywhere for leaks.
chefkenmore Member Since: 11 Jan 2015 Location: Fearnan perthshire Posts: 756 ![]() ![]() ![]() |
That’ll save the pocket!
Had a specialist check out the car. MAF readings all normal so that can be disregarded in the diagnosis.
Grofus Member Since: 24 Mar 2017 Location: Co Clare Posts: 577 ![]() ![]() ![]() |
It can be done without removing anything. Depends how stiff it is I suppose.
Thanks Grofus,
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2666 ![]() ![]() |
Just because the MAF readings are normal doesn't mean they're truthful. Can you start swapping MAFs from another vehicle? |
So, you have ruled out turbo and hoses, cracked manifold, turbo actuators, map sensors. Trans adaptation reset done.
I have been there believe me on this issue when you talk about losing the will to live! The fault code relates to the boost side of the turbo so the MAF sensors (just next to the air cleaner box) are not involved. You could try swapping the MAPT sensors in the inlet manifolds and see if the fault swaps sides. That's a 10 minute job. One plug and one screw per sensor and just pull them up and out. Also check if the left one (bank A) seems to be crudded up with oil etc. Clean with brake cleaner but don't get cleaner up inside the sensor as you might damage it. If the fault changes to bank B that is the problem. Replacement sensors are about £50 each IIRC. Previously a 2008MY Tonga Green Vogue SE 3.6 TDV8 |
Hmmm. Rereading thread my post may be superfluous. |
You may find error codes are revealed by different diagnostics tool. Like many I bought a GAP BT IID tool and would be lost without it. Previously a 2008MY Tonga Green Vogue SE 3.6 TDV8 |
Ive tried fitting a new maf to replace the one which i thought was reading low but no dice. Tried a combination of the 3 mafs I had to hand and nothing no difference.
rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119 ![]() ![]() ![]() |
Again, I would check the 90 degree hoses and short rear hoses. The are not shown clearly in this workshop diagram, but the rear is located near the 12 and 90 degree is coloured green along with sections of plastic piping.
