![]() | Home > Technical (L322) > 3.6 TDV8 issues following split boost/intercooler hose |
Grofus Member Since: 24 Mar 2017 Location: Co Clare Posts: 577 ![]() ![]() ![]() |
you can edit posts with a laptop or tablet but not on a phone
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2745 ![]() ![]() |
During removal and refitting you may be bumping the nearby air-box so any wiring near or on the air-box may be getting a jiggle, such as the connector for the MAF. |
MarianaWestminster Member Since: 14 Jun 2018 Location: UK Posts: 757 ![]() ![]() |
My throttle looks like picture 2 Rar. Its clean and moves freely when commanded by SDD with me watching.
You will just have to fiddle with wiring in an area then see if there's any change, then try another area. If the cover is being R&R'd then leave it off whilst hunting down the culprit, which could be anywhere the cover touches if triggered by the cover. You're getting very close to solving the mystery. |
rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119 ![]() ![]() ![]() |
👍 ______________________________
cheezels Member Since: 23 Apr 2016 Location: Sunshine Coast Posts: 279 ![]() ![]() ![]() |
Have you tried leaving the plastic engine cover off yet?
Had the cover off a few times cheezels with bo difference.
Worth biting the bullet and taking it to a dealer for an opinion? 2007 3.6 TDV8 |
Decision time. Do you feel its air restriction or electrical. Given that the split in the hose was clean I would suspect electrical and, more specifically , a broken wire. It's all that's left. Get an auto electrician to sort it and end the saga. I feel your pain. Good luck. 2007 Vogue TDV8 in Zermatt Silver with Charcoal |
A second set of eyes, perhaps even carefully watching as you go through the process of removing then refitting the hose that at least sometimes temporarily fixed the problem. |
I am not really sure if electrical or air restriction Grofus. I don't think it would be a broken wire as the ecm would report a fault code for this as the sensors are monitored.
Sorry mate. I’m away at sea for a few weeks otherwise I would definitely help 2007 3.6 TDV8 |
So ive actually managed I think to find a problem with the damn thing!
Good news and good luck tomorrow |
